Air line diameter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hogleg, May 13, 2017.
  1. Hogleg
    Hogleg Medium Load Member
    311
    258
    Nov 20, 2016
    Salem, Illinois
    I am reworking an old truck with bad air lines. Is there any guidelines or literature that can tell me minimum line sizes for various components? This truck has had numerous hacks to it over the years and I cannot trust just replacing what is now present. I am using nylon hoses now but replacing rotted rubber.
    Current list -
    1. min diameter from compressor discharge hose (1/2in ID) back to the dryer. Was using 1/2 in ID rubber. Is Nylon ok for this application or should I stick with DOT approved rubber. My 2007 international uses rubber here and then starts with Nylon for everything behind the dryer.
    2. min diameter from secondary (front axle) tank to foot valve. They have 1/2 in ID rubber now. Should I stick with the same or replace with either 5/8 or 3/4 Nylon.
    3. Is 1/2 OD nylon OK for feeding from the dryer to the wet tank and then splitting the same to the primary and secondary tanks?
    etc...
    John
  3. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Most applications used 5/8 stainless braid or high heat to dryer, 5/8 nylon to tanks. 5/8 feed line off wet tank to primary and secondary tanks. Usually 5/8 but 1/2 will work from tank to foot valve. And 1/2 or 3/8 as signal line from foot valve to relay valves.
    BoxCarKidd and Hogleg Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    The cloth? braided high heat I sometimes use is blue, that maybe a brand thing, and some have outlived the truck. It is also less expensive.
    I only remember hard copper or stainless braid from the factoy. You need at least 3-4 feet of that to disapate heat before you go to a regular hose.
    The advantage of the blue hose is that it is not worn through as easily as the other two.
    There is also a blue high heat rubber hydraulic looking hose just never used on on a truck. The 7.5 HP shop compreeser has one that's 5,7,9? years old.
  5. Hogleg
    311
    258
    Nov 20, 2016
    Salem, Illinois
    I have a 36 in braided 5/8 OD, 1/2 ID compressor discharge hose that I bought from Velvac to come off the compressor, then I switch to 1/2 in ID rubber air hose down to the dryer. From the dryer to the wet tank I went with 1/2 in OD Nylon. I think I should change that out to 5/8 OD Nylon given that the ID of the 1/2 is around 3/8 in. 5/8 ID is .445 in. Probably need more volume to feed the tanks. I went with 1/2 OD Nylon from the wet tank to each of the dry tanks thinking that the pressure is split between the incoming pressure and the dual outputs. However, if one of the tanks need to be replenished quickly, 1/2 may be restrictive - right? Maybe I should also go to 5/8 there?
    Since I need to buy some 5/8 anyway I think I will run the front axle tank to foot valve in 5/8 also.
    Thanks for all the help, guys!
  6. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    I thank the 5/8's Cllne is talking about would be ID, #10 hose. 2505 Terragaters use a #8, 1/2" ID hose and they work. Just never saw that on a factory set up truck.
    I would go 5/8's ID from the compressor to the wet tank and beleive that is what Cline ment.
