We have a 2004 Kenworth T800 that has started leaking air out of the drivers side rear abs modulator valve. It only leaks when you step on the brake pedal and is leaking out the exhaust port on the bottom. I’ve tried pinching off the brake chambers for that side to see if maybe one was back feeding through...no change. I’m suspecting the valve is bad but thought I’d ask to see if any of you might have any other ideas?
Air leaking from ABS modulator valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Xzachtly, Mar 27, 2018.
If the modulator valve leaks continuous when service is brake applied, replace it. Air is leaking by the vlave seat.
Pierce septic, xsetra, Heavyd and 1 other person Thank this. -
rank Thanks this.
1. Do I just call the KW parts counter and ask for a modulator valve from a pre ABS truck? We used to have a 1995 T600 I could use that VIN.
2. Will this non ABS modulator valve cause the truck ABS light to stay on? NYDOT will give me a ticket for that on a 1998 or newer truck.
3. Will the non ABS modulator valve cause the trailer ABS light to stay on? -
If you find yourself getting stuck often where just the powerdevider alone is not enough to get out, consider adding lockers to your current truck or on your next truck purchase.
I have also seen on Paccar trucks an "off road"switch that can disable the abs and traction control systems temporarily during slow speeds. I would suggest getting with your dealer to see if maybe this can be added to your truck as an option to save you some frustration. I have not looked into this but do recall seeing it in trucks in the past. I do understand you know what your doing as a driver.rank Thanks this. -
Goodysnap Thanks this.
rank Thanks this.
Switch has to be held for 3 sec or so then the traction light should turn on in the dash signifying the system is currently disabled.
rank and spsauerland Thank this. -
