Air leak in tractor protection valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ozdriver, Dec 19, 2015.
  1. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    Here's a question I saw on Reddit/trucking, which seems to be 90% newbies. Anyway, anyone got any ideas? I wouldn't mind knowing the answer myself.
    "For the past few days, I've been hearing a constant hiss coming from my tractor valve. It doesn't happen all the time but if it does, it will go on for the entire day.
    I just brought it into a shop and we could not recreate it no matter what. The guy obviously is writing me off because I don't know much about trucks (only been in one for 11 months), but I know it's there as when it happens, it will happen for ####### hours.
    If I'm driving and it happens, I'll watch the psi drop to 100 then the compressor kicks in and this will happen repeatedly.
    In the shop today, nothing, no leaks whatsoever.
    Am I going crazy or has this happened to someone else? Any tips on how to get it to happen?"
    Someone help the poor guy out lol
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    If it's hissing through the red valve it's either a bad valve or the trailer has a big leak. That's all that valve does- supply air to trailer
    Ozdriver Thanks this.
  4. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    If you twist them does it go away? Does the trailer have a tire inflation system? Matter if it's warm or cold?
  5. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    The shop guy is writing you off?it's not your job to do his job.he's telling you he doesn't know.try tightening the red knob.they do come loose sometimes.
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    When you say tractor valve , are you talking the yellow parking brake valve .
    If so you have a leak in one of your parking brake maxi pots.
    It will only leak when button is pushed in.
    As soon as you park and pull your button out it will stop.
    To help diagnose it , block your wheels from rolling then release all your brakes then shut your truck off and listen
    It won't leak if you park your truck with your brakes applied
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    He said some days it doesn't do it at all, but some days it does it all day. My guess is that it's the valve itself, and if he will try twisting the knob a little, I'll bet he can get it to stop. If it was a brake biscuit, it would do it all the time, and the shop would have no problem recreating the problem.
  8. AModelCat
    154,281
    When I hear tractor protection valve, I think of a valve like the Bendix TP-3, which is the valve that prevents air from leaking out of the trailer service line when bobtailing. Could you clarify that @Ozdriver?
    ShooterK2 Thanks this.
  9. Ozdriver
    767
    1,390
    Oct 16, 2015
    Australia
    I've got no idea, I was only looking at the guy's post on Reddit. I did come across this YouTube video which explains it pretty good though
    Edit : I imagine the guy on Reddit is talking about the park brake on the dash
  10. AModelCat
    154,281
    Everything he said there was spot on. Is your air leak from the push/pull valves in the dash or from the service line to the trailer?
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    I used to agree with Shooter 100% but had one trip me up. The driver had been complaining about a similar situation for about two weeks. That truck only traveled 15 miles back and forth as hard as it could go. Numerous people looked at it multiple times, no problem. When I drove it one afternoon it had a sudden air pressure drop and the maxi's were coming on in the road. Found a park brake chamber leaking. After the air was lost it corrected itself and I drove it to the shop. At the shop it worked perfect.
