When I change my oil, I notice quite a bit of air bubbles as the old oil drains. when peridocally checking oil on dip stick, there is at times a very tiny air bubble on dip stick. never saw this before ??![]()
Air in oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Jun 20, 2010.
If you are over the full mark it can be the crank frothing the oil, in which case getting it back to the full mark will make it go away. Otherwise just keep an eye on it. If you get signs of coolant mixing there is concern.
I guess that is why I am concerned. had lots of coolant in oil a few months ago had inframe done. so far only 20,000 miles on inframe. dont see the white milky look on my filler cap like before inframe & so far no noticeable coolant loss, unless it is a very small amount. could, what looks to me like air bubbles be coolant in the oil? it is either air or something else. I never saw so many bubbles when changing oil. though after old oil is out in oil pan after a lil while the bubbles dissapear, if that means anything, BUT, when I take from 15 gal pan & pour into oil jugs when filled the bubbles reappear on top again, then dissappear after a lil while, just like when first draning into pan. with oil & coolant mixed, would the coolant go to the top or is it heavier than the oil & go to the bottom? I am less concerned about air if it is air than coolant. thanks for the opinions. -
Are you using Lucas? Lucas will create air bubbles if very much is used, as it does not have anti-foaming agents in it. Also, are you sure your dipstick is correct. You may have way more oil in the engine that what is called for, but have the stick read full. Had that happen before. It could be possible the wrong dipstick was put back in during the inframe.
Well for over 11 years I would add lucas in every oil change. never saw bubbles in oil. the last oil changes since inframe, have NOT used lucas, got bubbles. as far as dip stick lengh, could be. shop had identical junk truck out back that we used parts off of. though it was identical. my mechanic said it is air bubbles. if it is air, I am not as concerned if it were coolant, but how would air... why would air be in oil ? but then I am thinking after I drain old oil & the bubbles dissapear, why or how would they reappear when I re pour oil into smaller jugs? if it were air, would not it escape & be gone? dont make sense to me why or how air would incorporate itself over & over in the oil after it is out of truck. taking 2 gallon jugs & filling one with old oil & poring back & forth from 1 jug to the other, I get bubbles. I may try a test & take some of my car's old oil & mix with small amount of coolant & shake up & see if I can duplicate the bubbles. I think it could still be coolant left in from inframe.
Why not have an oil sample checked and be sure? A couple other ideas would be to make sure the crankcase breather is clean and not plugged with gray goop from previous problem, and just another thought is high detergent oil will sort of bubble or foam sometimes. Good luck.
Are you using a different brand of oil? No two have the same additive package. That could be the problem. As far as Lucas, I was saying not to use too much. I never use the requested 1 gallon. I use less than half that. The oil is still sticky, but dillutes the oil additive package less, and does not thicken up the oil.
Try putting their suggested 20% mixture into the trans and rears. I lost about 1 mpg, and the truck felt like it was running in sand. I had to drain new oil out of all three members, and replace with more new oil to get my mileage back. Not cheap to do, but the loss in fuel mileage would soon eat up the cost. -
I just changed my oil on my car yesterday. got lot's of bubbles. I think I am just paranoid
after spending so much & having so much work done on truck, that if I smell, see, or hear anything out of the ordinary, I think there may be a problem. sorry for the waste of time. thanks for all who gave opinions. after going over 11 years & never having a breakdown on the road, I just wanted to keep it that way.
