Air horn won't stop
Discussion in 'Questions From New Drivers' started by Dfjohnson65, Jul 7, 2017.
  1. Dfjohnson65
    Dfjohnson65 Bobtail Member
    Jul 7, 2017
    im driving a 2018 Kenworth t680 daycab and I used my air horn and now it won't stop going off
    IluvCATS Thanks this.
  3. gwilli89
    gwilli89 Light Load Member
    74
    102
    May 4, 2016
    Illinois
    Ahhh, so you're that guy 3 spots down from me at the Pilot....
    Haha, kidding. Don't know what to tell ya bud. I'd be trying to get it disconnected real quick, or figure out which fuse it's on. Especially depending on where you're parked at.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,529
    18,013
    Nov 1, 2010
    Burnsville, MN
    I don't think my Cascadia has a fuse for that. It is a cable I pull, so it is probably a direct connection to an air line.
    If that happened on this truck I would be trying to find the air valve at the end of the cable, or a kink in the cable in between.
  5. gwilli89
    74
    102
    May 4, 2016
    Illinois
    Oh duh. Airhorn. Didn't even think about the whole fuse concept on that one. Oh boy it's been a long day haha
    SingingWolf Thanks this.
  6. Moosetek13
    14,529
    18,013
    Nov 1, 2010
    Burnsville, MN
    The Volvo might have a fuse. It is activated through the steering wheel so there is an electrical connection.
    But I don't think a blown fuse would keep it activated. Just the opposite.
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Fuse + Airhorn = ?????
    Erf... snip that air line to the #### thing real quick. Worry about the problem at the shop. Remember you can always bleat the city horn inside your steering.
    Find another tractor to run if possible. That one is got some thing going on with it now. yeesh.
  8. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Stay away from the beef and bean burritos and the problem should go away on it's own in about 6-12 hours.
    Grubby and SingingWolf Thank this.
  9. TripleSix
    127,994
    Day cab...
    Where the lanyard is, there should be a removable panel. Take the panel off and you will see the little air valve thing. I had one get stuck, and so I turned off the engine and let the horn bleed down the air tank. Then I sprayed the valve and wiggled and tugged the lanyard. Never had another problem.
    The day cab should be easier since it won't have all the interior trim that a road truck does.
    Grubby and lagbrosdetmi Thank this.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    DONT snip the line you will have a constant air leak. If what six said won't work take line off and bend it over and tape it till you get to the shop. Or clamp vise grips onto the line to block air flow.
    AModelCat, x1Heavy and TripleSix Thank this.
  11. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    It's true that it will be a constant leak. And your solution would take care of it. Thank you for helping out. I forget the details at times.
