Instructor told me something odd today during in-cab inspection. The two air needles on the gauge, I understood them to be a needle for the primary and a needle for the secondary, both separate air-brake systems.
He said no, that one needle was for the air for the tractor, the other for the trailer. That doesn't make sense because if one system failed you would lose half the brakes on the rig.![]()
Air gauge, why 2 needles?
Discussion in 'Questions From New Drivers' started by J Man, Jan 13, 2012.
Page 1 of 3
To clarify, he was talking about the main air gauge, not the application gauges (because our trucks do have those for tractor and trailer separately).
It also made a lot of sense.
Thank you for your enlightening reply. -
You're correct - one is primary air and one is secondary air. Primary air provides air to your drive axle brakes, as well as your trailer axle brakes when the foot brake is applied. Secondary air applies air to the brakes on your steer axle, and will provide air to your trailer brakes when the hand valve (Johnson bar) is applied.
This doesn't speak well for your instructor. -
sweetdaddy915 Thanks this.
sweetdaddy915 Thanks this. -
To fully go over the dynamics of it would take me a long time to type out - if you'd like to read the specifics for yourself, then do a search for FMVSS 121, which are the federal regulations regarding vehicle air brake systems. No, if you have a failure in one of the air systems, you will not lose service braking capabilities. However, you need to shut that truck down ASAP if that happens.
As for the Johnson bar, it doesn't bypass anything - it engages the secondary air system. If your secondary air system goes out, it won't function.The Challenger and J Man Thank this.
Page 1 of 3
