Air dryer
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Sandsailor, Jan 18, 2024.
  1. Sandsailor
    Sandsailor Bobtail Member
    21
    9
    Feb 26, 2023
    Ok so has it ever happened to you guys that the air dryer is stuck purging open? I thought my airlines froze. So as an emergency I poured a bottle of rubbing alcohol into the lines from the compressor to the dryer. It just spilled it out the purge valve. Al’s free much trying just to not be stuck. I grabbed a 10mm socket and tightened it until it stop purging. It’s running fine now. But it’s that a sign to get a new dryer? Or was this dryer just “loose” from factory? I bought it new like a year ago.
  3. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    813
    1,584
    Dec 15, 2021
    Bossman bought a brand new 579 2 years ago,he was pulling into the scale in Arizona and it dumped the air and locked up the brakes,purge valve was stuck open.
  4. AModelCat
    154,260
    NEVER put alcohol into an air system in front of the dryer. It will wreck the desiccant in the dryer cartridge.
    In my experience its either been the purge valve is gummed up or the governor has been bypassing.
    At this point you should change the dryer cartridge (should probably be changing it every year or 2 anyways). I would check the purge valve to see if its sticky. Some dryer manufacturers have that valve available as a kit.
    NightWind and Last Call Thank this.
  5. Sandsailor
    21
    9
    Feb 26, 2023
    Update: the alcohol didn’t do squat. It just dumped it out the purge valve on the floor like an AA sponsor to the sponsee trying to hide it.
    The compressor stopped making pressure, took the governor line out and it spitted out all the alcohol and it started building pressure again.
    limping like this until I can make it home tomorrow.
  6. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Sometimes you can put the palm of your hand on the purge valve and block the air coming out and it will loosen the purge valve and it will start working again. If not you have to decide on a new dryer or just a purge valve replacement.
  7. SomeCanadian
    SomeCanadian Light Load Member
    151
    415
    Nov 11, 2021
    As a temporary measure I have pulled the valve and greased the o rings. As temporary as that should have been, I’m not sure if or when it got replaced. I know it worked well for at least three months.
  8. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Sounds like your drier is full of cr*p and the purge valve is taking the hit.....get a new desiccant cartridge, remove the old one, clean out the drier housing and you'll probably be ok unless the purge valve seals are just done due to the contamination.
    Worse case - new dryer - best case cartridge and purge valve kit.
  9. NightWind
    NightWind Road Train Member
    2,616
    18,579
    Nov 11, 2006
    Sunny South, AL
    Replace dryer filter every fall If dryer acts stupid get new one. Mines not that ecpnsive.
  10. Sandsailor
    21
    9
    Feb 26, 2023
    I just bought a new one. I don’t want to risk it for 200 bucks. Got a new one and peace of mind
    Rideandrepair Thanks this.
  11. Sandsailor
    21
    9
    Feb 26, 2023
    Mine was 200 bucks at fleetpride. Money well spent for peace of mind
