air compressor wont cut off til it builds to top of gauge
Discussion in 'Trucks [ Eighteen Wheelers ]' started by marc386999, Aug 10, 2013.
  1. marc386999
    marc386999 Bobtail Member
    6
    Aug 10, 2013
    Hi, woke up this morning and suddenly have an issue with my air. it keeps running til it builds all the way to 150(as higj as the gauge goes).
    Then i heat the releasr valve cpme on and it dumps air til it gets all the way down to about 50 and then just repeats the provess over and over. doesnt leak while the air is building up, so i dont know whats going on. any helpful idead would be appreciatefd, tjanks
  3. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    Not exactly sure what the issue is but it needs to be fixed. If its not cutting out at the proper psi it could blow a hole in the air compressor. I've seen it happen one time.
  4. RJC
    RJC Bobtail Member
    23
    13
    Jul 26, 2011
    Dothan,Alabama
    Change the air govenor on the compressor.
    Ezrider_48501 Thanks this.
  5. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Exactly. Pretty easy fix, 2 bolts. Fairly cheap part. Whatever you do, don't keep running it like this until you fix it, or you will blow a hole in something!
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    agreed on the Governor
    seems like most the time too much preasure is the governor then not building pressure tends to be a stuck unloader.
  7. dixieworkx
    dixieworkx Light Load Member
    52
    25
    Nov 15, 2012
    replace governor...buy an extra one they are cheap {11-15 bucks} and will go out at the most inopportune times...and yes extreme high air pressure will blow something {lines/tanks/etc} apart
  8. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Not quite guys....yes his governor is bad ( tap on it driver...it might live a bit longer ) but what he's hearing is the tank safety's lifting. There is a pop off valve where ever air can be trapped and build like air tanks.
    Everybody has them....glad his works...be a heck of a boom......
    Driver ! Got an air drier? When was the last time you changed filter???? That is one cause of gov failure. ( dirty air )
    JMO
    x#1 Thanks this.
  9. dixieworkx
    52
    25
    Nov 15, 2012
    not sure about tapping on it...might help...there is also an adjustment screw on the bottom under a plastic piece..you can back off the pressure with this, but would only do it to get somewhere you could get a replacement....there are safety valves on tanks, air dryer, etc...these do fail, get clogged, get hit with road debris and jam, etc...a driver a month or so ago found this out the hard way when one of his primary tanks exploded....yes it was a heck of a boom...made the news....a clogged air dryer filter will cause gov failure as the gov releases overpressure through the air dryer...if the filter is clogged the air has no where to go...
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Maybe he was one of those guys whose air dryer popped off every 20 seconds and someone crept over in the night and undid his unloader line so they could get some sleep!
    Skunk_Truck_2590 Thanks this.
