Wondering if I need a new air compressor. When sitting at an idle my truck will not build up any pressure at all. I have to bump the idle up to 1,500 rpms and it takes a while.
This next problem was strange until my mechanic figured it out. I had a hole in my trailer air tank so I was losing pressure all the time. If I was on flat ground doing 65 it would not build any pressure at all until I hit a hill and the truck started to hump it up the hill. This was confusing to me and until my mechanic explained it to me. I had no idea the compressor got it's air from the boost. So, the problem is that the truck won't build any pressure unless there is boost. I could be totally out of air going up a hill and when that boost kicks in that needle goes at Mach 10 and builds up pressure in seconds.
Air compressor problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Skate-Board, Sep 16, 2015.
Page 1 of 3
Compressor gets its air from the Boost ?? You got me there!
blairandgretchen Thanks this.
( creak of hood hinges, click of flashlight, author goes investigating . . . )
icsheeple and Skate-Board Thank this. -
Skate-Board and blairandgretchen Thank this.
You can check if your compressor is not worn. Build air and look dash gauge how fast its building. It should build in 40 seconds Between 85-100psi.
But first thing check air leaks(air lines, fittings, dryer valve) second disconnect air compressor air outlet, start engine if its not building air your unloader valve bad. -
Where is the unloader valve?
Page 1 of 3
