Air Compressor on Cascadia running continuously
Discussion in 'Trucks [ Eighteen Wheelers ]' started by popmartian, Jun 3, 2011.
  1. popmartian
    popmartian Road Train Member
    1,015
    489
    May 31, 2009
    the System Builds Pressure to 125 PSI. then I hear the Tanks High Pressure Release Valve "POP" about ever 60 seconds as the Compressor seems to be building up excess PSI. I only noticed this becasue all my other units shut off the compressor at 125PSI and would kick on at 100 PSI. I have heard this "POP" sound on other trucks and figure it is a bad Governor on the Air Compressor. Any suggestions before calling or going into the Shop! 2010 FreightlinerCascadia with DD15 engine.
    THX
  3. AUSSIE DAVE
    AUSSIE DAVE Road Train Member
    1,032
    176
    Feb 21, 2010
    OZ - Brisbane
    could be the govenor or the unloader valve, govenor is usually cheaper and easier to replace.
    popmartian Thanks this.
  4. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    here is a service bulletin for that problem.
    123456 and popmartian Thank this.
  5. popmartian
    1,015
    489
    May 31, 2009
    Ok! :) I do have one more question. Is there a auto cutout switch to turn off the compressor at 125 PSI or does the Air compressor run contiunous? the article refers to a cutout. I have heard the sound in the article and it is different, usually like a da da da da da da da sound. The sound I am experiencing happens about every min and it is much louder like single "POP".
  6. FYDA FREIGHTLINER CINCY
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    sounds like it maybe a stuck unloader. i believe we have replaced 2 or 3 compressors on that model engine.
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Loose gov or major air leak? That would be why the compressor would be continuous duty. That's the spitter valve on the dryer you hear right? The high pressure safety valve on the tank should be 150 psi.
    I have a fix when you guys park next to me at night. Loosen the unloader line, then I sleep in peace.
    Hardlyevr Thanks this.
  8. Volvo92906
    Volvo92906 Light Load Member
    120
    63
    Jan 14, 2011
    I just worked on a truck last night with a DD15 in it. The air was building to about 140 and I could hear air purging from what sounds like something near the back side of the engine. I dont know if there is a compressor back there or a valve.. But I saw a line moving every time it purged. It was a 2012 engine.
    Anyhow.. having replaced the governor, and adjusting it, and putting a new air dryer filter on the problem was not resolved. The truck was building air normally it seemed.. but just sounds like a high pressure pop off. It would drop the pressure about 10psi and build back up and do it again. I wonder if this is what the TSB is for.... I wish I knew more about the newer trucks. This stuff is getting too advanced to try to take care of without any form of information. Im used to seeing a compressor on the front of the engine, with a line to the governor, and a line to the air dryer, then to the tanks. This integrated governor on the dryer housing with no lines and valved compressors you cant even see with all the emissions is difficult....
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    To test the governor and the unloaders, you need a fitting to be able to connect it to shop air, build the system untill the governor unloads then feel if the air is leaking past the intake the unloaders are leaking, then soap test the air Governor and air dryer unload er for leaks.
    You do not buy parts you test and confirm.
    Scrapper Thanks this.
  10. Volvo92906
    120
    63
    Jan 14, 2011
    I am fully aware of how to test... However as I stated.. It purged in cycles.. it did not leak. The unloader valves were working correctly in the sense that they were not leaking. I dont throw parts at anything if I can help it. I have a GOOD KNOWN governor I use for testing... I didnt just throw on the part against the customers will and expect him to pay for it.
    From talking with another guy, he told me the DD15's have some sort of regen mode and they have a longer purge cycle and lose air pressure.. but its normal. I am going to check and confirm today at Detroit Diesel.
  11. Cascadia
    Cascadia Light Load Member
    86
    43
    Jan 18, 2014
    Hi there
    I know it's been a while but did you find what the problem was?
    I'm having the same identical problem but I noticed a leak at the unloader valve when the eng is running, but it actually stops as soon as you shut eng off, and the Primary tank only drops to about a 100 psi.
    Thanks
