Air compressor hose
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lazer, Jul 27, 2021.
  1. Lazer
    Lazer Road Train Member
    1,728
    2,725
    Jan 22, 2017
    The hose from air compressor leading to the air tank gets hot. I know compressed air will get hot, but how hot is too hot? I don’t have an infrared gun. I have replaced the small line that runs from the tank, back to the governor, using vinyl/plastic, using zip ties attached to this main air steel braided hose to attach to. Will this small air hose, and zip ties melt?
    1995 3406 KW T800
  3. bad-luck
    bad-luck Road Train Member
    3,246
    5,944
    Nov 16, 2013
    Baltimore, Maryland
    If you are talking about the braided steel line that comes off of the compressor. It will get hot, this is the reason that it it braided steel. The plastic lines should not get hot.
    Bean Jr. and spsauerland Thank this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,467
    9,694
    Mar 30, 2014
    Zactly! A compressor is putting out 3-4 times what a turbo puts out. Before they used air-to-air, they used aftercoolers to cool the turbo boost. They used engine coolant which meant that 18-30 pounds of boost was worth cooling to 180°. So 120 psi has to be real hot!
    bad-luck Thanks this.
  5. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    It may not melt it, but it will get brittle faster from the heat.
    Bean Jr. Thanks this.
  6. Big Road Skateboard
    5,687
    29,604
    May 2, 2021
    Discharge hoses are rated around 1000*, and 300 psi, buy they are still plastic inside. Obviously a different composition
    BoxCarKidd and Bean Jr. Thank this.
  7. Lazer
    1,728
    2,725
    Jan 22, 2017
    That’s what I figured, I moved that little return line away from that braided steel hose, routed it under the drivers side, to the back, then over to rear of the air tank instead of the front. Now it’s plenty far away from the hot transmission, the steel braided hose, and the exhaust pipe.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Teflon.
    Big Road Skateboard Thanks this.
