I have a Volvo D13. I don't own it. I just drive it. Does anyone by any chance have a picture of where the discharge line is connected to the compressor? Or maybe an idea of how I can spot it?
- For many years I've been pouring air line anti freeze into the glad hand between the tractor and the trailer but the alcohol seems to mess the grommets up. I was recently told that the ideal place is to take the line off the compressor and dump 1/2 cup in there. Is this true? And if so can you give me an idea of where this line is at?
I'm told that the best place to put your airline antifreeze is in the line that's going from the compressor to the air tank.
Air Compressor Discharge Line
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MooneyBravo, Nov 19, 2022.
An evaporator in that same line is still the best way to put alcohol vapor into your system as long as you keep alcohol in it.Last edited: Nov 19, 2022
AModelCat Thanks this. -
Volvo air compressor is mounted to the rear structure. So it's not as easy as pouring it in the discharge line like on an older motor where it is right up front. You basically have to be on top of the transmission to get to the connection off the hard line.
MooneyBravo Thanks this. -
As @beastr123 said, do not pour it into the system ahead of the dryer, it will wreck it. Pour it in after the dryer.
It’s on driver side near firewall
