Air-compensated pintle hook air supply
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by nebula828, Oct 2, 2021.
  1. nebula828
    nebula828 Bobtail Member
    6
    Jul 17, 2015
    I operate a boom truck for work. It's a straight truck. Occasionally we'll hook up a pup trailer. My truck has an air-compensated pintle hook that I use to hook up the pup trailer. It has an air chamber behind the hook that extends a snubber which presses against the lunette ring to eliminate slop within the hitch.
    The other day I noticed that the air chamber is connected to the service air line instead of the supply (emergency) air line. As it is currently installed, the snubber only extends when I press the brake pedal. Under any prior experience I've had with these types of hitches, the air chamber has been connected to the emergency air line so that the snubber is in continuous contact with the lunette ring so long as the trailer air supply button is pushed in in the cab.
    My dispatcher spoke with a mechanic at our local repair shop yesterday who assured him that the air chamber is currently installed properly; it's only supposed to extend the snubber when the brake pedal is pressed. He claimed that if the snubber were in continuous contact, it would prevent the trailer from turning easily, and it's only really needed when the brake pedal is pressed. Someone please tell me that this mechanic has no idea what he's talking about. This can't be right.
    The air chamber on an air-compensated pintle hitch should be connected to the emergency air line so that the snubber is in continuous contact with the lunette ring. Right?
    RocketScott Thanks this.
  3. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    Your mechanic is wrong, it should be hooked up to the emergency line
  4. RocketScott
    RocketScott Medium Load Member
    579
    946
    Apr 10, 2013
    Kentucky
    I’ve never seen one hooked up to the service line
    Sounds like your mechanic is looking for an excuse not to fix it
    nebula828 Thanks this.
  5. Ridgeline
    22,112
    113,286
    I just had two of these installed on trucks used for huge construction trailers I bought for a contract.
    I stopped on at the place that installs them and I discussed how these are installed with the guy who does the work, he said they never go on the live brake line for any reason, it always goes on the emergency trailer brake line.
    I drove one of the trucks after the new hitch was installed when I picked up one of the trailers, what a huge difference in how it feels.
  6. nebula828
    6
    Jul 17, 2015
    Thanks for these responses. Good to know I'm not losing my sanity more than I already am.
    Caterpillar Cowboy Thanks this.
  7. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    I didn’t know this even existed. Man that would make a huge difference.
  8. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    I've acquired trucks with them both ways. If they are acquired with them plumbed to the pedal line they get replumbed to the brake release line.
    I'm right to me as far as I'm concerned.
    I've gotten them the other way so I am obviously wrong to someone else.
