Air Brakes test when upgrading liscense? ;)
Discussion in 'Questions From New Drivers' started by srekcurt9291, May 31, 2018.
  1. srekcurt9291
    srekcurt9291 Bobtail Member
    11
    4
    May 17, 2018
    I have CDL B with airbrakes upgrading to A. Am i going to perform airbrake test again? such as 1.Applied Pressure Test 2.Warning Light and Buzzer 3.Tractor/Trailer Protection Valve Pop Out? or just we will just do skill test and road test?
    And what will happen to my CDL B when i fail to upgrade it? will i lose it?
  3. Ridgeline
    22,101
    113,190
    Nothing will happen to your class b.
    But you have to take the air brake portion of the pre-trip with the class a.
    What's the big deal anyway?
    It is part an inspection and should be a periodic check during pretrips.
  4. Noobtr
    Noobtr Bobtail Member
    40
    12
    May 30, 2018
    Hey sorry i have a question.
    Is air brake knowledge test multiple choices?
  5. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    Only in Canada. :)
    Noobtr Thanks this.
  6. Noobtr
    40
    12
    May 30, 2018
    Thanks alot. I am in alberta getting my 1z.
    SteveScott Thanks this.
  7. Moose1958
    Moose1958 Road Train Member
    15,090
    33,171
    Dec 17, 2010
    Williesburg, Virignia
    It's been a while since I seen these tests, but outside of the general knowledge test (50 questions) I think the others are 25 or less questions tests. In the US, I have no idea about Canada.
  8. AModelCat
    154,240
    In BC you needed to do the air brake course, which consisted of classroom theory and then an air brake pre-trip on an actual vehicle. Then you had to take your paperwork to ICBC and do a multiple choice test to have it added to your license. I imagine Alberta is somewhat similar.
  9. Ridgeline
    22,101
    113,190
    OP, don't take this wrong but you all need to put in your location when asking questions, maybe the powers at this site make it mandatory to do so to get through the member sign up process.
