Air Brake leakage PSI's
Discussion in 'Questions From New Drivers' started by dogchimp, Feb 22, 2013.
  1. dogchimp
    dogchimp Medium Load Member
    673
    190
    Jan 31, 2013
    Ive noticed my manual, and the practice tests all appear to have different rates for what is acceptable for how fast air brakes should leak, I believe for a dual system combination vehicle, it should be no more then 4 psi per minute, can some one post this info to help me out?
  3. 379exhd
    379exhd Road Train Member
    2,925
    3,160
    Jun 25, 2012
    rolling through hell
    Dual air combo brakes applied 4psi with the truck off. And 3 psi with no brake applied and the truck off single is 3psi applied truck off and 2 psi truck off no application
    dogchimp Thanks this.
  4. chopper103in
    chopper103in Road Train Member
    2,407
    6,562
    Apr 11, 2010
    Crossville,Tn
    [FONT=Arial,Bold][FONT=Arial,Bold]Test Air Leakage Rate.
    [/FONT]
    [/FONT]
    [FONT=Arial,Bold][FONT=Arial,Bold][/FONT][/FONT]With a fully-charged air
    system (typically 125 psi), turn off the engine,
    release the parking brake, and time the air
    pressure drop. The loss rate should be less than
    two psi in one minute for single vehicles and less
    than three psi in one minute for combination
    vehicles. Then apply 90 psi or more with the brake
    pedal. After the initial pressure drop, if the air
    pressure falls more than three psi in one minute for
    single vehicles (more than four psi for combination
    vehicles), the air loss rate is too much. Check for
    air leaks and fix before driving the vehicle.
    Otherwise, you could lose your brakes while
    driving.
  5. dogchimp
    673
    190
    Jan 31, 2013
    Aha I can see clearly now where I got confused, thanks guys!
  6. 379exhd
    2,925
    3,160
    Jun 25, 2012
    #### cdl book quotes. I just push the pedal down and hold it. Idt i can put 90 psi to the brakes in my 2000 with the pedal hell pulling the trolly bar all the way down with 135lbs in the tanks i can only get 100 lbs back to the trailer brakes if that. And dogchimp in my comment when i said single i ment single vehicle like a straight truck or a bob tail rig. Hell who checks the air brakes durning a pretrip anyways i mean you only need your brakes to stop...and theyll automatically stop you if the compressor fails so who cares about pretriping them lol. Thats sarcasm i check mine everytime i pretrip my truck...it fails because i have an air leak in my abs valve but the brakes themselves function fine and she stops quick when she needs too
  7. tinytim
    tinytim Road Train Member
    5,145
    19,774
    Oct 29, 2007
    Northern Ontario
    I'd like to meet the person that can tell if that little dial moved 3 psi.
    379exhd and briank Thank this.
  8. 379exhd
    2,925
    3,160
    Jun 25, 2012
    Lmfao good point:biggrin_25514:
  9. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    And I am still in Pursuit of a truck-tractor/trailer that the pressure does not drop more than the allowable when you release the park brakes.
    Best regards
