Air brake connectors
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Mar 22, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    What is the proper name for these connectors.This was leaking a little from the air tank. Cut the tubing and it still leaks,so I'm going to buy a few of them. Where is the best place to get these and other air connectors for the truck? Also how straight does the cut Need to be? Cause I tried a few times and it still leaks. Thanks.
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    It leaks because there's a o-ring inside that's dried up and cracked.
    Take a needle nose plier and pull the push in connector off and you will see a o-ring inside.
    Take a metal L-shaped pick and use it to carefully pick it out, go to the automotive store or a place that sells o-rings and match it.
    Put the new o-ring back in the fitting and place the brass connector back in and you have just rebuilt your fitting, just as good as new.
    xsetra Thanks this.
  4. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Truck dealers, truck parts store, fleet pride.
    Napa, advance auto.
    The guy at dealer couple days ago called it a " push in" air fitting.
    Not sure if that's the official name.
  5. lwlevens
    623
    427
    Feb 9, 2018
    Thanks guys just went to Napa and bought a few of them.Now I know how to rebuild them to. Cool, awsome site.
  6. boneebone
    2,294
    2,365
    Mar 13, 2009
    That name (push in), or quick connect air line fitting.
  7. homeskillet
    homeskillet Road Train Member
    5,636
    40,704
    Jun 1, 2013
    Dayton, OH
    "Push in" or "Quick Connect" air fitting.
    The cut need not be "perfect", but using a razor blade or VERY sharp knife and making the cut as square as possible will help reduce the failure rate.
  8. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Or you can throw it in the garbage and fit a real DOT brass compression fitting in its place that won't leak after a little bit of vibration.The plastic ones really suck. The only reason OEMs use these is for ease of assembly on the line. We call them quick "connect" fittings. Often mistaken as a quick "disconnect" which most often they are not. I will say a good idea to throw an assortment in your roadside toolbox for emergency repairs, especially the unions. You can fix a rubbed line with a razor knife quick like.
    AModelCat, spsauerland and BoxCarKidd Thank this.
  9. Mattflat362
    Mattflat362 Road Train Member
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
  10. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    homeskillet and spsauerland Thank this.
  11. Mattflat362
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
    I just have them for emergency and then once I used one to fix my air seat...I have 3 sets of brass also...
    spsauerland Thanks this.
