07 9400i with eaton rear ends, no air leaks, new leveler. The leveler is adjusted right also. It has pressure in the bags but it will not come to ride height when we put heavy loads on it. We didn't have these issues until the last month or so. What could be going wrong?
Air bag/leveler / ride height problems on heavy loads???
Discussion in 'International Forum' started by sbatson, Jan 24, 2013.
No enough air pressure to the ride height valve. There is a pressure protection valve that will cut off the air bags at a certain pressure to protect the rest of the truck from loosing air in the event of a blown air bag. If the valve screws up it could only be letting a few psi back to the air bags, which is enough to lift the suspension empty, not enough when loaded.
Sometimes they screw direct into the air tank. They are 2' long and about an inch across. Some have a round part on one end. Tap it gently with the end of a screw driver and see if you can get the air flowing.
Ill try that tommorow. I noticed to that the compressor kicks off and on like it should but seems to get stuck around 100 unless I rev the crap out of it.
Well I was talking about the air gauge in cab when the compressor is on it gets to around 100 and kinda stops until I rev it then it will slowly fill to cut off. The bags seem to have pressure in them but just doesn't come back up to height. They will come up very little and soon as I start driving they flatten out. Now if its a empty trailer they seem fine but when it's loaded it does this.
You would have to remove the supply line to the ride height valve and put an air pressure gauge on the line and see what pressure is available to the valve. I was working on a 2000 9400I today. The pressure protection valve for it was plumbed at the second supply port of the rear service brake relay valve.
Majors121 Thanks this. -
On the supply line, how much pressure should it have? And the pressure valve is on the tank correct?
Good question, LOL. You know, I really can't remember ever having to change one of those valves in almost 20 years. I think that valve may be closer to the ride height valve. Screwed into the tank is one spot it could be too. Like I said in the last post, I saw a truck a few years older than yours today, and it had the protection valve about 1 foot from the ride valve. International doesn't have air line schematics like they do with electrical, so I really don't know where it would be. Basically the valve should allow no pressure to the air bags until the system pressure is up to about 70 psi or so. Not sure on the exact pressure, somewhere in that neighborhood. Once the pressure is up high enough the protection valve will open and allow system air to the ride height valve. So technically, if you have 100 psi in the tanks, there should be 100 psi at that valve. The valve could be stuck partially closed and only allowing 10 or 20 psi to the air bags, and that would explain why it can't raise a loaded trailer to the correct height.
Well on a normal 80,000 load seems fine but I have about 90,000 or so now and it aired up fine but dropped while it was sitting there and compressor kicked on and it aired up again. I did notice that I have a brake chamber leaking, could that be letting pressure out of bags?
