Aftermarket Mud flap hanger..
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckerPete1990, May 6, 2020.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    So i bought 4 State Trucks
    I'm really not that good with Electrical stuff.... It has 3 wires
    Red,Green,White...
    I Was wondering if i could somehow make them flash with my Turn signal? Also whats the best way to tap into the lighting in the rear on a T680?
  3. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    You'll need a half inch drill and a good drill bit. Get yourself some 4 pin trailer wiring, a butane torch and solder, some heat shrink tubes, wire cutter, strippers and about 2 hrs.
    If this confounds you, you should maybe have someone else do it for you.
    haycarter and Caterpillar Cowboy Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
  5. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    Already drilled it out and everything was just wondering if its able to make them blink guess ill work with it 2moro.
  6. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    I put the same set on my freightliner. It used to have just the two center lights and the reverse light.
  7. mtntopbound
    mtntopbound Bobtail Member
    38
    71
    Sep 9, 2019
    Everywhere man
    If the truck originally had 2 taillights that were stop, tail ,turn, just wire them up and they will function the same. If the truck originally had 4 tail lights 2stop 2 turn you will need to rewire the outside lights on the hangers for blinkers.
  8. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    Red wire=Tail light
    Green=turn
    White=ground
  9. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    If you aren't good with electrical I'd let someone else do it. It's not a hard job at all but if you just hack into the factory harness and don't seal things up good you will have problems later on with wires corroding. Stop and turn signal lights are one wire, clearance or tail lights another and last is ground
  10. TruckerPete1990
    8,623
    5,376
    Jul 16, 2012
    Thanks I got them installed.
    HoneyBadger67 Thanks this.
