After jump starting, "no engine" shows on the dash.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by marpolsdofer, Feb 1, 2019.
  1. marpolsdofer
    marpolsdofer Light Load Member
    106
    31
    Apr 7, 2015
    So this is the 2nd time in 2 weeks I had to jump my 07 Sterling. The first time I tried to start it and it would turn over but I was running low on power. So I got to jumping it. I try to start it and got nothing. The starter relay would click but no starter and the dash would read back NO ENGINE. Screwed around a bit, never fixed it. I come back the next day to try and figure out what fuse I may have blown (cause hey now it way warmer). First thing I do I just try to start it and everything is working perfectly. Starts and runs just fine.
    Today it was close to dead, had to jump it again (have not worked the last few days). Same thing happened but saw no engine for a brief second and never saw it again. This time around I made sure I disconnected the jumpers and what ever heaters are plunged in, see if that changed anything. I also made sure not to spark anything when I hooked it up.
    When I came back 30 min later starter and everything worked but still told cold and not enough power to start it.
    So anyone know what is going on? I am thinking some type reset able fuse or something in the ECM to protecting it?
    Just so you know I cant keep a charger on it because some one will steal it and I don't typically need to jump it. Also the block heated broke last month so waiting tell spring to fix it.
  3. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    First thing I would do is check all terminal connections for corrosion and loose connections.Than look at the batteries. Check them for bulges and water level, then isolate and charge fully. Anything under 12volts after full charge is scrap. Do that and see what you have. When you're working with batteries be very aware of battery acid. It is very corrosive. Always wear safety glasses and gloves,rubber are best.Also wear old clothes as acid will burn holes in everything. Service the batteries then see what you've got. 9 out of 10 times, batteries are the cause of no start. The other 1 is everything else. Hope I helped, if not repost.Good luck.
    Reason for edit: Misquote
  4. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    I agree, sounds like a bad connection or a battery or two acting funky.
    Tombstone69 Thanks this.
  5. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    You really should fix that block heater as soon as possible. If you are having any kind of starter battery or starting problem, without that block heater in this cold weather you're multiplying exponentially how hard it is to start that engine.
    Even without starting problems, in any kind of cold weather you should always be plugged in. Always.
    That should be right on the top of your list to fix.
  6. marpolsdofer
    106
    31
    Apr 7, 2015
    It is on the bottom of the list. I got bigger stuff to work on but not needed right now. I only discovered it was not working about a month ago after I checked it when I was having a coolant leak. It is not easy to get at either turbo has to be removed.
    I tend not to fix stuff in the winter unless it needs to be done or I get hold of my friends parents shop (while they go on vacations).
  7. marpolsdofer
    106
    31
    Apr 7, 2015
    Been there done that battery are good, thermals are good. Before jump battery voltage was 12.2volts. When it really cold that will go quick. After I jumped it was 13.6 volts but could not use it because like I said after I jump it I get a no engine code display and/or no started but the relay turns on. Come back next day works fine like nothing happened. Come back 30 min like there was never a issue everything working fine minus minus what every the voltage has settled at and its still cold outside.
  8. Dino soar
    4,789
    26,858
    Dec 8, 2017
    I can understand saving money and waiting to do things that you can put off. And I'm not here to argue with you or give you a hard time.
    But if you're talking about the block heater that you plug in when it's under say 40 degrees outside, then you really should have that fixed immediately if you're in any climate that's under 40 degrees. It's no wonder that you're having starting problems.
    That block heater allows your engine to spin half a turn and start rather than cranking and cranking and cranking and cranking and shooting ether and jump starting and all that sort of nonsense. All that does is wear your batteries out and wear your starter out which it sounds like you"ve already done.
    It's your truck do as you wish. But to me it really doesn't make any sense to change a block heater in the summer when we are in the dead of winter and you're going to end up replacing at least your batteries and your starter instead of the block heater. To me that's kind of a backward logic to replace all of that instead of making sure your truck will just start easily in the cold weather. It is incredibly hard on the batteries and the starter to crank an ice cold engine in cold weather. By Springtime you might be replacing your starter and your batteries again. That can't be cheaper than just having somebody put it in.
    Also be careful if you're shooting that truck with ether in the cold weather. I knew a guy that did that in the dead of winter and he broke his crankshaft. I knew another guy that blew the compression out of his rings. Using ether on an engine that has a block heater is just plain stupidity.
    It's a lot cheaper to just fix your block heater honestly.
    I'm done here. Good luck. Be safe.
    I'm out
    stillwurkin and Tombstone69 Thank this.
  9. jaielv
    jaielv Light Load Member
    62
    12
    Dec 30, 2010
    joliet,il
    It will help if you post engine model.sounds like a shorted out battery or two.how old are your batteries?then again we don’t know what type of truck so we can tell you how many grounds, relays,to check or if you get power to the Ecm pin#72 to many outs with not enough info. I got Cummins INSITE and Cat Et and I’m able to send you diargrams but need info.
  10. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    What he says. Good batteries, block heater are a must in cold weather. I know its a pain, but it is what it is.
  11. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    The batteries may show good voltage and still be shot. Go to the automotive parts store and pick up a battery draw tester, about $30 and check the condition of each battery.Disconnect each battery after they have been fully charged and test them individually. This will.show if you have a bad battery. If there are borderline batteries, replace them as well. It is best to have all of them in the same condition.
    The tester can also be used to see what your charging is doing.
    You mentioned that the block heater is low on the list of things to do. What other issues are there that may be times into your starting problem?
    spsauerland Thanks this.
