Aerocab sleeper sizes?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Boardhauler, Mar 21, 2012.
  1. Boardhauler
    Boardhauler Road Train Member
    1,687
    3,186
    Dec 21, 2008
    Ballin' in it for Shakey
    I'm confused.
    I see Kenworth Aerocab sleeper sizes listed in The Truck Paper as 50", 54", 60", 62", 63" & 64"
    Did KW really make all these sizes?
    Does anybody know how the length is measured since the sleeper sort of wraps around the side of the cab unlike a Unibilt?
    Can anybody help me with BBC lengths for the different size sleepers?
    I need to have a short enough tractor to get a 48' trailer down to 65' overall.
    Thanks for any help.
  3. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    After just looking at what is available from KW, there is and 86", two 72", two 60", and the 38" all available as aerocabs. The ones listed as with two are stand up and flat top
    The other sizes may be for the T2000 or T700 I didnt look into those.
  4. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    I know KW makes the 38, 62, 72 aerocab sleepers for the T660, T800, and W900L. With the exception of the 38, you can get double bunks in both the 62 and 72. I also know there is a modular flat top version of 42in and 60 if I am mistaken. Hope this helps.
    KH
  5. The Challenger
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    T200 I believe is 75in and one smaller one at 60in.
    T700 is one size only.
    KH
  6. Preston3
    Preston3 Bobtail Member
    12
    Sep 29, 2009
    crofton, KY
    studio sleeper 86inch
    Lalito.1234 Thanks this.
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    I have never been able to figure out how and where they come up with those sleeper measurement in inches. Freightliners say 70 inches for the Centurys I had, and now my Volvo 780 says 77 inches, using either number for those trucks and measuring from the back wall forward meant that the back half of the driver's seat was in the sleeper. I always wanted to try logging sleeper berth while driving and use that measurement!
    To be under the 65 foot limit you will need to consider the tractors wheelbase and the positioning of the 5th wheel too. The Centurys I had, 70 inch bunk, 120 BBC, and around 228 inch wheel base, with the 5th wheel centered over the axles would make that with a 48 footer.
  8. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    it is rule of thumb 72,60,86,BBC means bumper to back of cab.
    Cetane+ Thanks this.
  9. Hardlyevr
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    but if you look at some of the specs they say things like 120 BBC which is what the regular hood Century was or 112 for the short hood, and either model you could get with a 58 or 70 inch sleeper. And I could never figure out where they were measuring the sleeper from, maybe to the end of the wing on the outside of the back, cuz there sure was NOT that much inside.
  10. dirthaller
    dirthaller Road Train Member
    1,012
    11,790
    Sep 22, 2011
    Coloratah
    Kenworth measures the aerocabs from the back seat. They measure the modular sleepers from the back of the cab. If you have an old modular 60" its basically the same as the 72" aerocab. They take the same amount of frame space. 42" is the only modular sleeper KW makes anymore. Compare a 48" unibilt with a 62" aerocab. 63" unibilt with 72" aerocab. 70" unibilt with 86" aerocab(studio).
    Boardhauler Thanks this.
  11. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    Nope those are sleeper sizes... my Pete is 127"BBC but has a 63" sleeper...
