im looking to get into the business and starting with a dually hauling 3 car. I have a driver who doesn’t have a cdl. Does anyone have any recommendations for a trailer on the lighter side that can haul 3 cars while keeping in mind i cant go over 26k?
Advice on 3 car trailer for non CDL?
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Atlanticus trucking, Jun 29, 2018.
Page 1 of 5
A 3 car with a driver in it is bankruptcy waiting to happen.
Doealex, Western flyer and Kozakvod Thank this. -
If your doing interstate commerce, you need to check on the CDL even under the 26K. Never been a car hauler, but where are you going to find 3 cars that weigh less than 18K? whats the truck & trailer weigh?
I did a quick search, and the 3 car trailers I'm finding have a GVWR of 14K-18K lbs. If the GCVWR (C is combined, meaning trailer and truck) is more than 26k lbs, that puts it in Class A CDL needed.
Heck, I was kinda mislead at the beginning. Curb weight does matter, but only if it's more that the weight rating. Say you find a lightweight trailer, and the truck is on the lighter side too. Say both GCVWR is 26k or less. Well, if, once you load 3 cars on the trailer, you are over the GCVWR, not only do you trigger the full must have for license and the like, you also will be overweight and put OOS until that is fixed.Oldironfan and Atlanticus trucking Thank this. -
Ahh its all beginning to come together. I appreciate you explaining things. I already have my DOT, and am in the process of getting insurance. I haven’t heard of a drive qualification file or a med card. Can you explain that a little more?
I looked up the f350 as well as the trailer and your numbers are correct. 13k for the truck and 14-18 for the trailer which would put the GCVWR at 27-31. How are guys running these set ups without cdl? Are the dot officers more lenient because they are hauling less then 26k combined and everything else is in order? -
North Carolina requires CDL class A if the trailer rating is 10k lbs or more regardless of Gross combine weight. Even if it is empty, you still need Class A. There are signs saying this at all of their DMV and I confirmed it with a few of NC State troopers.
Other states may be different. It is much much easier to just get irp plates, and get Class A license.
My previous 1 ton pickup and 3 car wedge setup was as light as it can be and still weigh in at almost 15k empty. Putting on the 3rd car will get it over 26k. My setup was 2002 ford f350 with no truckbed and stock fuel tank and Kaufman 3 car wedge trailer with only 2 single tire axles. I was shocked that the actual weight was so high. -
Here is a link to the CDL manual, it's on page 8. https://www.ncdot.gov/download/dmv/handbooks_CDLmanual.pdf
Class A Combination Vehicles. Any combination of vehicles with gross combination weight rating (GCWR) of 26,001 or more pounds falls in Group A provided the GVWR of the vehicle(s) being towed is more than 10,000 pounds.brian991219 Thanks this. -
But you are correct. As soon as one gets out of business, 10 more pop up. New numbers, different logo, same bs.BigBob410 Thanks this.
Page 1 of 5
