Advice for starting a small expediter/hotshot business
Discussion in 'Expediter and Hot Shot Trucking Forum' started by scfan87, Nov 14, 2019.
  1. JonJon78
    JonJon78 Road Train Member
    7,041
    37,553
    Jul 1, 2018
    As been stated with the amount of trucks out here I find it hard to believe a good paying load is having problems moving. The trucking industry is beyond over saturated with trucks.
    FlaSwampRat and Lite bug Thank this.
  3. Ridgeline
    22,103
    113,210
    please explain this - "initially start with loads under 10,000 lbs"
    Also never go into business with a friend.
  4. scfan87
    scfan87 Bobtail Member
    8
    I guess I should say a GVWR if less than 10k on the trailer and less than 26k total. Since it doesn’t require a CDL correct?
    Also, I actually have a very successful small business in real estate management with two of my closet friends. It’s all about going in with a solid business plan and airtight operating agreement in order to keep business and friendship separate.
  5. scfan87
    8
    Im not saying you’re wrong at all, I’m just going by his numbers. It’s something he’s spend a good bit of time collecting data. It might be in our best interest to further explore our area and look into this more.
  6. scfan87
    8
    This isn’t something we are doing to be a full time job. Stay small enough to limit the hours we spend operating while still making enough to pay for the equipment and make some extra money. Then build upon that if we have success.
  7. npok
    npok Light Load Member
    160
    172
    Sep 26, 2015
    You're gonna have a tough time finding a driver. What you're thinking of requires somebody to be on call, but only for part time work.
    It also really sucks getting paid 25% & working full time hours, but still only bringing home 4-600/week. Because the rates look good 1 way. Backhaul, what's that? Gotta get back to the yard ASAP in case they call again.
    Run your numbers including $1k/week net pay...minimum. If you're rates aren't good enough to support that, you might reconsider your plan.
    Also, load/unload times might kill your day if you're doing multiple stops.
    Lite bug and scfan87 Thank this.
  8. jeffman164
    jeffman164 Medium Load Member
    594
    557
    Dec 4, 2012
    Part time business but full time fixed expenses . A lot of variables ......
    24kHotshot and JonJon78 Thank this.
  9. crocky
    crocky Road Train Member
    1,732
    1,577
    Jun 28, 2017
    Where will you get these magic elusive drivers and why would they work for you vs one of the many other established trucking companies? Also with rates as they currently are.. How do you plan to pay your drivers, pay for your equipment, pay all the other bills and pay yourself?
    JMHO, but this is more the type of business that you start up yourself as the driver/ owner operator and then maybe after you built up history and working relationships add on other trucks/drivers but even then it's a hard road.
    With that said.. it's likely easier to do it with semi's than hotshot trucks.. Hotshot is very limited on freight..unless maybe you do cars but cars don't pay much. With hotshot many, many brokers and shippers will not work with you or the load requires air-ride or it requires a 48 ft trailer ect..ect you are already working with limited freight and then if they call it a partial the brokers try to get you to run it for .50/mile even though it might be a full load on your hotshot trailer..
    dispatching a single hot shot truck and getting it good paying loads is a time consuming job. You sometimes have to watch the load board like a hawk all day maybe 2 days to get that 1 load before it disappears 5 mins after it was posted because some other guy was hungrier than you.
    It's much, much easier to get a semi truck a good paying load, hot shot is more a niche for owner operators IMO not people trying to build up a fleet of trucks.
    If I were to try and hire on trucks/drivers I'd probably go with car hauling because even though the rates are lower it's more consistent and much easier to get loads for a hotshot truck vs freight loads. You don't have to spend all day trying to find loads for a car hauler like you do with freight, but freight generally pays better, but car hauling will be dependent on where you live..
    singlescrewshaker and scfan87 Thank this.
  10. Lite bug
    Lite bug Road Train Member
    1,391
    28,682
    May 3, 2014
    Columbus Ohio
    This is good intel for you to consider.
    singlescrewshaker, npok and scfan87 Thank this.
