Advantages/ disadvantages of S Corp VS LLC
Discussion in 'Ask An Owner Operator' started by Rich_Trucking, Jan 12, 2013.
  1. Rich_Trucking
    Rich_Trucking Light Load Member
    248
    21
    Dec 11, 2012
    I live in CA and I am looking into getting my own authority.I only have one truck. I've been told to go with an LLC because I currentlyHave only one truck.I would like to know what your thoughts are?
  3. pokerhound67
    pokerhound67 Heavy Load Member
    801
    665
    Oct 30, 2012
    its not a simple answer. llc allows certain freedoms...no need for meetings and minutes for example. lower start up costs (no corporate filings). but all net income from an llc is taxed the same as a sole proprietership, ie. paying self-employment tax (both sides of medicare and social security). with s-corp, you can pay yourself a fair market salary, and any net profits can be given to the owners as distributions, taxed at lower rate. llc dies if one of the owners dies or declares bankruptcy, scorp does not. a good idea would be to go to the small business administration and read up, so you can make an informed choice.
    worktruck and Rich_Trucking Thank this.
  4. tomkatrose
    tomkatrose Light Load Member
    224
    161
    Oct 22, 2010
    Los Angeles, CA
    Tax reasons aside, one of the primary reasons for establishing an LLC or S-corp is for liability protection, protecting you, your home, etc. from being sued when it should be against just "the company". For that reason, you have to show that the legal entity is not just a cover for that. Lawyers will try to "pierce the corporate vail" and go after you if they can so you should also consider which entity you can best maintain compliant. As pokerhound67 said, for an S-corp, you need to have board meetings, keep minutes of the meetings, etc. If you don't, it's easy to go after you personally. An LLC only requires one meeting a year.
    Rich_Trucking Thanks this.
  5. EZX1100
    EZX1100 Road Train Member
    4,017
    5,711
    Aug 18, 2012
    i was told the main reason to have an LLC is if you get more than one truck, if not, then you may as well go sole proprietorship because the liability will be the same, taxes are the same, and simpler to function
    Rich_Trucking and BigBadBill Thank this.
  6. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    CA is a state that comes right out and tells you if you are sole person in LLC you are treated as individual. Well, except they let you pay corp taxes.
    You need advise based on state you are in. LLC is state designation and Corps are federal.
    States treat these different. In IL it is more expensive for LLC vs. S-Corp on taxes.
    Also, more forms on your taxes with LLC. So if person doing taxes charges based on forms then it will be more expensive on return.
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    As a one truck owner operator there is no hiding from the liability . In a catastrophic event you either get sued as the owner or as the driver. But your butt is on the line.
    So the only real difference is taxes, a good local accountant is priceless .
    snowblind, Autocar and Rich_Trucking Thank this.
  8. Rich_Trucking
    248
    21
    Dec 11, 2012
    Great info everybody, thanks, should I file for the corporation myself or go through an agent/ lawyer
  9. BigBadBill
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Why are you asking this? Did you not read the posts? Seems you need to talk to a professional in CA to determine if this is even worth it. $800 a year minimum corp tax (LLC or Corp). Are you going to save that in taxes? There is zero liability protection.
  10. Rich_Trucking
    248
    21
    Dec 11, 2012
    Well the main reason I want to go LLC instead of sole proprietership Is because if I buy another truck or hire some O/O's, I want to be ready for that.
    I talked to an agent here in Sacramento and he wants $1300 to get my AUTHORITY for me, including 48 state permits, licensing, MC#, DOT # ETC, but I think thats way too pricy, Can I do all this myself and save money.
  11. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Can you do it all yourself? Yes, you can. It'll save you that 1,300$. Its basic info needed to obtain your authority/dot and all the good stuff. There is a thread on here for obtaing your authority and what is needed. Search is your friend! Good luck
