I'm curious what additives all you drivers use in the winter and also the summer. Is there any brand you like better? What reason are you using the additive? There are so many additives out there I'm wondering if I should be using more of them.
I've used the Howes anti gel in the winter ... looking for other suggestions especially for summer
Additives ... What do you use ... Why and When?
Discussion in 'Experienced Truckers' Advice' started by GAShog19, May 5, 2024.
Page 1 of 3
None here, imo all are a bunch of BS snake oil.
I used to use Howes anti gel but no longer. Had zero problems this past winter. When I can burn through 150 gallons a day it’s just cash going out the stacks.
I’ll save my money for beer
Crude Truckin', Bean Jr., 2Tap and 4 others Thank this. -
Snake oil most of them IMO.
Don't know of anyone who uses any regularly or at all.tscottme, gentleroger and Concorde Thank this. -
I used Howes as well. Bought it by the case. Also filled my fuel filters with Howes every second change, it seemed to keep my injectors cleaner and it pulled stronger.
Winter I used it always including with blended fuel, any time the temp would be below freezing before the next fuelup.JB7 Thanks this. -
What engine are you running and year ?
singlescrewshaker Thanks this. -
I run a gal of filtered used engine oil here & there. Gotta get rid of it anyways..
Or wally world 2 stroke if its on sale..Feedman and Diesel Dave Thank this. -
only what's recommended by manufacturer
flood Thanks this. -
As per RAWZE(Cummins Guru), I run 1 gallon of WallyWorld gear oil GL 5 at every oil change on my ISX 15. For fuel additive, I’ve ran a few but ended up with Lucas. Cheapest I’ve seen it is at Wally world. I try to stay away from B-20 fuel, but if I need to purchase it, I get minimal and add the Lucas. Other than that, Lucas about every third fill up or so.
Howes anti gel. Clear liquid.
Don't know when it came out for sale. First time I seen it.
The truck didn't get used much this past winter. -
Nothing in summer and a number one blend in winter. No additives
Crude Truckin' and Lav-25 Thank this.
Page 1 of 3
