Adding reciever trailer hitch to semi frame
Discussion in 'Experienced Truckers' Advice' started by RepoweredRookie, May 14, 2022.
  1. RepoweredRookie
    RepoweredRookie Light Load Member
    137
    122
    Apr 16, 2019
    Hey Guys,
    Looking for you opinions about mounting (likely welding/drilling holes) on a bumper tow reciever hitch on the back frame of the tractor.
    1. has anyone seen it besides a pintel hook on a dump before?
    2. is welding/drilling holes on the frame a bad idea for a 12 inch dropped trailer hitch reciever
    I have a travel trailer or tow dolly I could pull behind the tractor, is the reason I want the hitch. 1999 Freightliner Century. Thanks!
  3. Hammer166
    7,339
    26,325
    Aug 18, 2007
    ~8600+' and loving it!
    I'm pretty sure that crossmember is reinforced if used with a pintle. You'll see freighthaulers with one mounted on the standard crossmember but there will be a weight limit sticker right there, as it's only good for moving a dolly around.
    Be easy enough to have a welder make up a crossmember with a receiver built into it.
    RepoweredRookie Thanks this.
  4. Dennixx
    Dennixx Road Train Member
    4,422
    13,923
    Feb 13, 2010
    twin cities
  5. AModelCat
    154,240
    Welding to the frame is generally a HUGE no-no!
    What you'd likely have to do is have a rear crossmember setup similar to what a dump truck has and bolt it onto the rear frame in order to get the receiver down low enough to get the trailer to sit level.
  6. Dennixx
    4,422
    13,923
    Feb 13, 2010
    twin cities
    I guess I assumed it's use would be recreational and licensed as a rv
    Don't know if that would make a difference on a weld vs bolt.
  7. AModelCat
    154,240
    There are procedures out there for welding repairs to frames but generally its considered a poor practice to weld anything directly to a truck frame.
  8. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    D.Tibbitt, RepoweredRookie and Dennixx Thank this.
  9. Hammer166
    7,339
    26,325
    Aug 18, 2007
    I should have been clearer... I meant have a welder make up a replacement crossmember to bolt in...
    RepoweredRookie, baha and AModelCat Thank this.
  10. AModelCat
    154,240
    I knew what you were saying. I was refering to the OP. Kind of looked like they were asking if they could weld a receiver to the frame.
    RepoweredRookie and Hammer166 Thank this.
  11. RepoweredRookie
    137
    122
    Apr 16, 2019
    Guys thanks for the responses, if I’m understanding you all, you’re saying replace cross-member (in yellow) with another cross-member I can weld/fabricate/add a drop reciever and ball to. Then keep the original for working. Is that right?
    Hammer166 Thanks this.
