Adding power steering
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Isxrookie, Jun 4, 2020.
  1. Isxrookie
    Isxrookie Light Load Member
    82
    46
    Jan 24, 2011
    New Orleans, la
    I just bought a Freightliner cabover 79. Anybody have idea how to add it or is there a kit? Any help would be appreciated.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,516
    6,570
    Aug 26, 2014
    You will not find a kit for that.
    The least expensive way is to find a bone yard truck and get all the parts. New filter and hoses. Wash the new hoses out also. Hope the pump and gear is good. One off a running truck you can steer is best but hard to find.
    Rideandrepair Thanks this.
  4. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    Can I take it off any truck. If so I have one I can take power steering components off of
  5. BoxCarKidd
    4,516
    6,570
    Aug 26, 2014
    No: However at a shop I used to work at a sector and pump were taken off an early 80's COE similar to yours. It had a Big Cam. The pump and sector were installed on a 4000 White with a Small Cam. A mounting plate had to be fabricated between the sector and frame. Two different drag link sections had to be found. One had to fit the pitman arm, the other the spindle arm and the had to screw together at the correct length. Then there are spindle arm and steering box hydraulic stop adjustments required.
    Watched a man work his brains out to do that another time. He was smiling when he got it together, turning the steering wheel back and forth in the shop. When he turned the steering wheel to the left the tires went to the right.
    Pitman arms are different with some applications as well.
    I thank TRW-Ross and Sheppard have same good information about adjustment on line.
    magoo68, Rideandrepair and AModelCat Thank this.
  6. Bean Jr.
    Bean Jr. Road Train Member
    5,537
    9,875
    Mar 30, 2014
    What are your plans for the truck? If it is to work it, well ok. If it is going to be a show truck, why bother? No power steering is a lot easier to turn than power steering that doesn't work. If you're not backing up and need to turn the wheel, they turn pretty easy, as long as you're rolling.
  7. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    Yea I’m gonna be working it. I would rather have some kind of assist. I tried googling ram assist
    Bean Jr. Thanks this.
  8. 201
    201 Road Train Member
    12,620
    25,902
    Apr 16, 2014
    high plains colorado
    What about an air-assist? Lot easier, and you still have the "feel" of manual, like Bean jr. sez, and assist when backing in. I wonder if you can still get that, that's what I would do.
    AModelCat and Bean Jr. Thank this.
  9. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    Yes I h
    yes I been googling that as well. Still trying to research
  10. 201
    12,620
    25,902
    Apr 16, 2014
    I drove a Mack with air-assist. It was a simple unit, just an air cylinder mounted to the tie rod, and a 2 way air valve. The only problem was, backing in a tough spot and jerking the steering wheel, you can run out of air.
    BoxCarKidd and Bean Jr. Thank this.
  11. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    I’m surprised I didn’t get more hits on this thread
