Adding oil in fuel intentionally? What would be the purpose?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Unidewking, Dec 24, 2018.
  1. Unidewking
    Unidewking Light Load Member
    84
    66
    May 3, 2018
    So a post on a facebook page just made me really confused and intrigued. Picture of a dude putting 15w-40 in his fuel tank. Read some comments but really confused still. Now from what i understand, diesel is a more refined oil so they are kinda similar but what would dumping atf, 15w-40, or used engine oil do to a fuel system? I know the systems are filtered but does it help lubricate injectors? Keep injection pumps go longer? Who thought this up first? How did someone figured out the ratios of oil to fuel? So many questions.....
    Maybe some old school truckers can help me out here. Thnx
    McMahons Trucking and A5¢ Thank this.
  3. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    … struggle to flow through the filter, used engine oil will clog the filter faster.
    other than that do nothing other than cause a smokey exhaust if there was enough of it.
    fuel system components are designed to be lubricated and cooled by the diesel that flows through them. adding oil into the fuel tank is pointless.
    on a side note, shove enough oil in the intake the engine will run on that alone. if the supply is of enough quantity it will run on it building engine RPM until, in some cases, catastrophic failure.
  4. Brandt
    Brandt Road Train Member
    4,405
    5,938
    Sep 17, 2012
    They used to dump used engine oil in tanks to get ride of the oil. You could just burn it off. Then you clogged fuel filters more. It was free and the oil would burn. They said ATF would clean the injectors. So dump a bottle in fuel tanks and clean fuel injectors.
    You can't do anything like on today's new emission truck and new fuel system. You will probably destroy the high pressure fuel system they use today. Today you can buy stuff made to clean injectors. They might help a little.
    Also the older engines like 1999 at later were built to run on the now old low sulfer diesel. I had a 1999 S60 Detroit and when they switched to ultra low sulfer diesel. They thought it would not lube the fuel and walls of the Pistons on the oler engine. I was adding engine back then but because I had oil sample showing I was getting more piston ring wear on the low sulfer diesel.
    They solved all those problem today
    Opus and A5¢ Thank this.
  5. Unidewking
    84
    66
    May 3, 2018
    ah ok so it was just something mechanics and drivers noticed to extend the life of the motors. That makes sense i guess. Its just not something that is universal and you dont just go round dumping atf or enigne oil into any semi. So what allowed the older engines to burn stuff thicker then diesel? Were alot of older engines just lower pressure when it comes to fuel systems? Is that why they started harder in the cold? Sorry i just have alot of questions....
    A5¢ Thanks this.
  6. Unidewking
    84
    66
    May 3, 2018
    I have heard that is sometimes what causes runaways. Is this correct? Ive not dealt with much in the diesel world. In my head im thinking fuel filters are made for deisel to pas thru which is much thinner then engine oil. Maybe the deisel would dilute the viscosity? Idk very interesting though.
    A5¢ Thanks this.
  7. DieselTech_Aus
    274
    309
    Dec 20, 2017
    WA
    yes, but typically only when copious amounts are fed into the intake. such as when the turbo fails and allows feed pressure into the CAC system.
    youtube some diesel engine run aways, it'll raise an eyebrow
    A5¢ Thanks this.
  8. Brandt
    4,405
    5,938
    Sep 17, 2012
    You could put a gallon of engine oil into a 130 gallon fuel tank and it will mix with the fuel and burn on pre emission engines. You do that today it probably clog up the DPF filter and mess up DOC filters in the emission system. Their is something in ATF fluid that will mess up the emission system. I believe the fuel pumps today have tight specs in internally also.
    I ran pure 100% biodiesel in my 1999 Detroit S60 back when Bio diesel was big thing for couple years. It ran just fine no problem burning it. The fuel pump had no problems with it. It was a simple fuel pump only like $200 to replace even it it did any damage
    SteerTire and A5¢ Thank this.
  9. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Back in the day, ATF was added occasionally to soften the O rings on the injectors, so they would seal better. This was common practice in the 1970s. Did it work, or was it just a wives tale? Who knows! Some of the old miltary engines were designed to burn gasoline, diesel, kerosene and just about anything you could dump in the tank!
    This was an era that had no sensors to speak of and everything was mechanical. The fuel was high sulphur and who knows what else was different in the old fuel. Today's engines/electronics would not tolerate such practices. Adding drain oil to a fuel system would plug up filters with the soot suspended in the drain oil. I think there would be codes popping up for emissions as well.
    91B20H8 and SteerTire Thank this.
  10. SteerTire
    SteerTire Road Train Member
    1,414
    2,346
    Nov 5, 2018
    Behind the wheel
    We used to dump it in the tanks back in the day. I wouldn’t do it with today’s engines.
    We also used ATF in the winter. Supposedly to help fight gelling. But as the temps dropped even further. We dumped a half gallon of unleaded in each tank.
    bzinger and A5¢ Thank this.
  11. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Older engines, pre-egr for sure, but mostly late 90's or older use lower fuel injection pressures and actually have larger holes in the injector tips so adding any oil to the fuel was ok and accepted practice. Actually, Cummins for one, had a system to add used oil to the fuel and burn it off. The mating parts tolerances were wide enough that any oil additives or junk in the oil would never cause a problem. Today is a very different story. Fuel injection pressures are about 3 or more times what they use to be. 33,000 psi or more! Injection part tolerances are tighter and nozzle sizes are smaller than they have ever been to accomplish this. This is why it is so important to never add anything to fuel other than a bit of winter conditioner if needed. Oil simply has too many additives that will build up and cause stiction problems or even nozzle clogging. Aftertreatment systems are also not meant to handle engines burning anything other than fuel.
    A5¢, Brandt and SteerTire Thank this.
