Adding anti gel fluid to my fuel tanks.
Discussion in 'Questions From New Drivers' started by BillStep, Nov 26, 2018.
  1. BillStep
    BillStep Light Load Member
    195
    238
    Mar 17, 2016
    At what outside temperature should I add an anti gel to my fuel tanks?
  3. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i'd not go below 32 degree's myself.
    rabbiporkchop and BillStep Thank this.
  4. BillStep
    195
    238
    Mar 17, 2016
    Thanks Buddy. I'm stuck overnight near Rockford Illinois. Due to the weather. It's supposed to get to twelve degrees. I'll put some in.
    buddyd157 Thanks this.
  5. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,501
    Oct 22, 2016
    North Dakota, Eh?
    If you cant add it before you fill, make sure you run the truck for 30 minutes or so after you put the additive in so it can blend with the diesel in the tank.
  6. BillStep
    195
    238
    Mar 17, 2016
    Thanks Crude. I have 3/4 tank of fuel and added a bottle. The reefer unit is not running until tomorrow but I think I will add a half bottle to the fifty gallon tank and run the reefer for a little bit. Also I think with the truck idling the vibration will keep the fuel "jiggling" around.
    Crude Truckin' Thanks this.
  7. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i personally, only add what the directions say per fuel tank capacity. no need to over do the chemical additives. i know at times, it does not seem like much per tank, but they got that crap figured out pretty well.
  8. Moose1958
    Moose1958 Road Train Member
    15,090
    33,172
    Dec 17, 2010
    Williesburg, Virignia
    I guess I am about to show my ignorance here, but I was of the understanding that the refineries changed over to a winter blend now. I thought this rendered these additives moot.
    Crude Truckin', tinytim and BillStep Thank this.
  9. Ffx95
    Ffx95 Road Train Member
    1,368
    2,628
    May 18, 2017
    Certain places don’t add the antigel blend or so I heard. Places tend to be below i10. Again I heard, don’t know if it’s true.
    Crude Truckin' and BillStep Thank this.
  10. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    the winter blend you are talking about a change in the fuel to cut done on some types of smog gasses (DEQ mandate) it has nothing to do the changing the temp that fuel will gell at. this is not the same as winter blendED that is a mix of diesel #2 (when we use all the time) and diesel #1
    the gell point of diesel depends on the diesel and how much BIOdiesel is mixed... 100% diesel will start to gell around 22-25 but 100% biodiesel will gell at 32 so somewhere between them is where your fuel will start to gell.
    for me I add anti-gell at 25
  11. Moose1958
    15,090
    33,172
    Dec 17, 2010
    This ARTICLE (if I am reading it right) seems to be contradicting you. There are some wikipedia articles too. However I hate to use wikipedia to link too.
    Relax, when I was active I also added when I bought fuel. If you ever get caught with gelled fuel you learn!
    BillStep and Crude Truckin' Thank this.
