Acid wash stained my stainless steel?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Chadwick, Apr 16, 2014.
  1. Chadwick
    Chadwick Light Load Member
    73
    6
    Apr 3, 2012
    Oregon
    I got a normal truck acid wash, and it wrecked my stainless steel rear light panel and stainless drop visor. Left like streaks on my visor, and splotches that look like hard water marks. My rear light panel is like streaked and browned and white/blue acid marks....anything I can do to restore the stainless? Why did this happen? Metal polish? Acetone or anything other trick I can do to clean it up nice?
    it seems to like react/look worse when I tried to clean the marks off
    thanks, pretty upset
  3. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Never let those morons put acid on your truck. Acid had one purpose only. To burn the crud off aluminum tanks and wheels right before cutting and polishing them.
  4. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Did you try rubbing it with super fine steel wool, or which ever coarseness that may match the original finish?
  5. KC Guardrail
    KC Guardrail Light Load Member
    199
    155
    Dec 7, 2013
    Stainless steel can be polished out just like aluminum. It takes a different jewelers rouge, one that's a little harder.
  6. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I would not use steel wool at all on the stainless it will scratch it up and be super hard to get the scratches out. I would try like cleaner wax. Meguriers is good! It could be that your stainless is a lower grade material and does not hold up as well as say 304. I know Road Works uses 2 different grades unless you spec the 304. Had a problem similar to yours.
  7. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Are you sure it's not just hard water marks? I'd try a little bit of Limeaway just see.
  8. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    If it is polished stainless, I agree, if it is brushed stainless it is widely accepted as proper treatment for removing surface stain or scratches.
  9. Chadwick
    73
    6
    Apr 3, 2012
    Oregon
    Yes it's all polished SS. are my visor and light bar ruined or do you guys think I can restore them? It's weird, my chrome bumper, SS 1/4 fenders, and SS Flap hangars all came out perfect...guess my drop visor and light panel aren't as high grade? Anyone got other products I can try or know what I can do to remove the stains?
    thanks for all responses so far!
  10. The Admiral
    894
    561
    Jul 18, 2010
    Akron,Ohio
    It's spelled Meguiars, cleaner wax it worked for me. If you use anything too coarse it will scratch the finish and then you will be really unhappy. Wash the surface so you do not scratch it with the dirt on it. If you have a buffer use a soft wheel with white rouge.
  11. Chadwick
    73
    6
    Apr 3, 2012
    Oregon
    Yep im a little familiar with meguiars, i'll pick some up and give it a try. Thank you
