Aching muscles
Discussion in 'Questions From New Drivers' started by hmor535, Jul 2, 2012.
  1. hmor535
    hmor535 Bobtail Member
    11
    Jul 2, 2012
    Hi all...I just started driving in April and the muscles in my right calf and left shoulder blade and left back side of my neck are very sore. I've tried getting more comfortable in the seat by streching while I drive (when I'm stopped and in the cab), stretch out some before I go, when I stop and get out I stretch out. But, I'm @ a loss to cure this problem. I'm 5'8" and 165 lbs. Any suggestions?
    Thanks!
  3. CAXPT
    CAXPT Road Train Member
    2,937
    12,605
    Feb 10, 2008
    Well those are muscles that sit still and can become stiff, but it sounds like you are meaning they are painful.
    It's possible you could have arthritis issues that are showing up now that you are doing a "repetitive" sedentary behavior. Age means nothing when it comes to arthritis.
    It's also possible you could have an under reported (by men) condition called Fibromyalgia. Historically it has been a condition mostly applied to women. Men don't tend to report what they perceive as mild muscle pain, etc. regardless the level of pain. It is a chronic condition that can be managed with regular stretching, massage, chiropractic, hot showers/baths, etc. Unfortunately it can also be treated by new medications, but if you take them, you won't be driving. Presently, only Rheumatologists can properly diagnose the disease, although other physicians are increasingly being trained out of Med school to diagnose it.
    One of the hallmarks of the disease is painful muscles that aren't moving, referred pain (emanates from somewhere other than where you feel it)....hence the stretching massage etc. helps...which is why I've suggested this for you.
    There are other reasons besides just this, it could be a more insidious disease of the musculoskeletal system, so best to ask/report this condition to your physician and get it properly diagnosed before long.
    Welcome to trucking. Learn to take care of your body with these new conditions, you're going to need it.
    Good Luck
    road_runner Thanks this.
  4. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    give your body more time. if you are older (over 40) pains will not be new to you. as you age in this business, they may get worse. never jump off the back of a trailer, never jump down onto the ground from your cab, this is what the steps are for, never run up and into your cab, use the steps and take it easy. if you have to load/unload your trailer..?? Wear a back support belt, and be sure to bend your knees and lift with your legs.
    when sleeping in your truck, maybe elevate your legs a bit, and do not use a pillow to support your head.
    finally, invest in some stock for Tylenol, and Aleve.
    your future will be requiring you to buy large amounts of these pain killers.
  5. stillayoungman
    stillayoungman Light Load Member
    58
    21
    Dec 31, 2010
    I had pain and tightness in the left shoulder area when I was driving OTR and it helped me some to stop using the left arm rest for a while. I also lowered the steering wheel just a bit and that seemed to help some.
  6. skellr
    skellr Road Train Member
    8,737
    12,184
    Jul 17, 2011
    The Village, Portmeirion
    My legs get store when I get dehydrated. You getting enough fluids?
  7. hmor535
    11
    Jul 2, 2012
    Thanks for the info! Yup, over 40...I'm 53. No, I don't jump off the trailer, I always use the steps to get in & out of the cab. I don't have to load the trailer but i do have to unload it and I already have a bottle of bayer aspirin.
  8. hmor535
    11
    Jul 2, 2012
    Thanks! I don't use the left arm rest at all...maybe I should try to use it??? I'll have to try and use it and see what happens.
  9. hmor535
    11
    Jul 2, 2012
    Yes, I think so. I have water and Gatorade in my cooler.
  10. Moosetek13
    Moosetek13 Road Train Member
    14,523
    18,003
    Nov 1, 2010
    Burnsville, MN
    A lot has to do with the truck you're driving.
    I always hurt more in Volvo's than I do in a Cascadia or ProStar.
    In my new Volvo it is a certain spot in the middle of my back on the right side, and my right shoulder.
    In my last Volvo it was a spot in my lower left back.
    In the Cascadia and ProStar I had very few chronic aches.
  11. camaro68
    camaro68 Medium Load Member
    627
    290
    Dec 17, 2011
    Tennessee
    Stick with water. A Dr. told me once, drink water not Gatorade, to get hydrated. The salt in Gatorade will actually dehydrate you. Salt defeats the purpose.
    RickG Thanks this.
