Acert water pumps
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tmtbob, May 8, 2014.
  1. Tmtbob
    Tmtbob Medium Load Member
    303
    186
    Mar 3, 2014
    Oklahoma
    I read a post awhile back where someone mentioned using an Acert water pump on an e model or maybe early c15 cause they move more water. Is there any truth to this. I've never heard of that before and need to be considering a new radiator to handle the horsepower I'm putting out or if the Acert pump works and cools better that would obviously be easier faster and cheaper to swap out than a radiator. Any info on this
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    yes they do. but you have to make sure your c-15 has
    straight cut gears not helic cut gears (teeth are at an angle) 6nz and up are straight cut. some of the older e-models also. change the outside t-stat housing and plate for the water hose on the back of pump and possibly the neck to the oil cooler if there are clearance issues.
    Tmtbob Thanks this.
  4. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    Thanks for the info. Mines a 6ts e model and I need to check on the teeth. I had the front structure off around Christmas and can't remember what's on mine. What years are we talking on the Acert or do you know of a serial number for easy parts lookup. Thanks again for your help.
  5. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    any of the c-15 acerts bxs,mxs,or nxs will work
  6. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    I'm interested in this also. My 6NZ seems to get hot just looking at a hill. Was thinking of going to a larger rad. might try this first.
  7. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    it wont make much of a difference in your heat issue swapping to the acert pump unless you do a larger rad core also. all the acert pump will do is flow the hot coolant quicker around the liners pulling the heat away at a faster rate.
    mtoo Thanks this.
  8. slippez
    slippez Bobtail Member
    22
    4
    Apr 13, 2014
    you could also get screwed on the core charge since there different
  9. wore out
    wore out Numbered Classic
    15,319
    184,960
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The flow of the pump and the capacity of the core need to match, not say you need an acert core there are several good aftermarkets offered. Or the pump won't work with current radiator till you can get a core especially if its time to change it but to get the maximum benefit they should match.
    bigguns Thanks this.
  10. Tmtbob
    303
    186
    Mar 3, 2014
    Oklahoma
    Thanks for the info guys
  11. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If you use DCA4 in the coolant, then I would check the cover plate for it being eaten away also if you do not have a water filter, that affects heat absorption, and dissipation as does having the proper antifreeze protection -40F, and without a water filter the impeller in the pump will wear.
    99% of new trucks come with power-cool antifreeze. people change to cheap ####,
    Just a thought!
