2008 Kenworth T660. When i turn the key I’m getting rapid clicking. I checked the batteries all good voltage and not corroded. The clicking is coming from the fuse box under driver dash. Found Ignition relay and bought new one still nothing. There is no audible clicking coming from starter area. In a pinch i sent power to wire that sits on top of the starter solenoid with the key in on position and it cranks right up. Starter is tucked inside of driver side frame and hard to get to. Any recommendations? Am i
Missing something?
Acert C15 Clicking no start.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by touch4450, Jul 24, 2023.
"Found Ignition relay and bought new one still nothing" Where was this relay? Did you replace a relay that was clicking? How do you know what it is for? If you can hold your hand on where the clicking is coming from turn the key and try to start the truck to find the exact spot of the clicking. Clicking can be caused by 2 things 1 - bad internal contacts on a relay that are burnt and won't stay closed 2 - not enough voltage due to loose or corroded cables, either externally, internally or both. Cables can get internal corrosion that can't be seen. Only way to find out is to do voltage drop tests. Multimeter set to DC volts with + on one end and - on the other end of the cable and turn the key to crank. Drop should not be more than about .2 - .5 volts. -
Ok thanks for reply. The clicking is coming from behind the abs relay. The Relay labeled IGN i changed even after testing it with multimeter. I suspect cables are corroded i will perform drop test tmr.
Tested battery cables and they all had zero drop in voltage.. now i understand why they call finding these electrical issues “chasing” . When i send power directly to the solenoid and the truck cranks no problem does that mean that they starter and solenoid are good?
Reason for edit: Left something out -
Here's a good one that explains it. Same on heavy truck as a pick up as long as 12v system.
Ford F-150 No Crank No Start: Engine Starter Motor Diagnostic Walkthrough! - YouTubeLast edited: Jul 25, 2023
Thanks for your help went through all fuses and found one blew thanks
JB7 Thanks this.
