AC not working, is there a DOT regulation about this?
Discussion in 'Experienced Truckers' Advice' started by ewill71, Jun 13, 2012.
Thread Status:
Not open for further replies.
  1. ewill71
    ewill71 Heavy Load Member
    759
    234
    Oct 3, 2011
    mcgregor tx
    I was talking to a ew drivers today, The company I am driving for has 2 trucks where the AC is not working, and one of the guys said there is a DOT regulation about this. Have any of you heard that there is? I am gonna research this , I dont think there is, but Sounds like there could be due to comfort for the drivers. If its 100 plus out and you get into a truck and drive 100 miles it can turn into 150 degrees or more.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    They dont check your heating and a/c. They arent safety issues to the public. Although the may check your defroster. On a level 1
    Dominick253 Thanks this.
  4. Shoestring
    Shoestring Light Load Member
    295
    202
    Jul 25, 2011
    Lehigh Fl
  5. ewill71
    759
    234
    Oct 3, 2011
    mcgregor tx
    thanks, I didnt think there was anything about it in the regs, but the DOT website puts drivers comfort as an contributor to accidents, it says that it causes fatigue.
  6. Shoestring
    295
    202
    Jul 25, 2011
    Lehigh Fl
    They know it can be a factor in accidents, but they have yet to pass a law that says it's required. I would venture there is large of amounts of $$$ being spent to keep it that way. (anything related to driver comfort is being fought tooth and nail. ) If there was law, it would mean more downtime for the larger companies and union fleets. As it stands now, they don't have to do anything until it's in the shop for something else, or they don't have to fix it at all. Pass a law that says it needs to work, and they will have no choice but to get it in the shop, before it can cause a failed inspection.
    roadranger550 and ewill71 Thank this.
  7. Opus
    114,730
    My impression is that if it's on the truck, it has to work. No?
    ewill71 Thanks this.
  8. Allow Me.
    10,642
    12,101
    May 28, 2009
    Rancho Mirage, Ca.
    Not true, only safety sensitive items need to work, like lights/brakes/wipers/ defrost. Not radios/a/c/sliders etc.
  9. ewill71
    759
    234
    Oct 3, 2011
    mcgregor tx
    That is true to alot of truck owners and some companies. But DOT doesnt recognize it that way, eventhough they inspect as if its there it needs to work. But thats basically on lights and items necessary things. The account I am on the guy in charge of the plant here says if you want you equiptment to be good you need to take care of it.
  10. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    If the ac isn't working due to a faulty blower, that falls under the heater/defroster rule, so that does have to be fixed. If the AC doesnt work due to a refrigeration system issue, then no. Now if the AC refrigerant is leaking through the evaporator and entering the cabin, that might be considered a safety issue. Im sure breathing refrigerant gas isn't particularly a good thing.
    roadranger550 Thanks this.
  11. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    There's no FMCSR that cover AC's. However, you might want to look at OSHA.
    rank and ewill71 Thank this.
  • Thread Status:
