AC Install in a Daycab?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by preppypyro, Apr 29, 2014.
  1. preppypyro
    preppypyro Bobtail Member
    36
    7
    Sep 10, 2013
    Hey guys and gals,
    I am looking at a different daycab truck, and have found a couple that dont have air conditioning, something that I would like.
    I was just curious if anyone has installed some sort of ac system on a daycab before, and what they have done. Like junkyard fit a system on, or an aftermarket system or...? I would be looking for a reasonably priced system as well, not those super expensive no idle type systems!
    I was reading a great thread in here about installing an ac system on a truck, and lots of cool ideas for trucks with bunks, but most of the ideas wouldnt work on a daycab.
    Hit me with your best shots! Thanks for any and all discussions!
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Were I to install in a daycab I'd go with an rv rooftop mount. Two reasons. First is simplicity. No underhood work required. No special brackets or piping to run either. Second is the ability to run the a/c without idling if I were to be in a situation where I wnted/needed it. Also rv systems usually have a heat option so you could have heat without idling.
    Heavyd Thanks this.
  4. preppypyro
    36
    7
    Sep 10, 2013
    Thanks for the reply.
    With an rv rooftop system, would a person not need a generator though? For the daycabs I run, there would be no where to install a generator to convert the power to ac, let alone if I could mount a generator, it would most likely get beat on pretty well from the crappy roads i take trucks on.
    That would be my only concern about a rooftop rv system. Maybe there are some that work off of the truck batteries...?
  5. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    I did some research on this about a year ago and found some dc units for boat cabins. Also found a couple of uniys that are pretty common in europe for small campers. You just have to be patient in your search. You can use an ac powered unit in combination with an invertor. A Coleman 13500 btu unit pulls about 1600 watts on full power. Dont think you'd ever need to use it in a daycab though lol
  6. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i would think running a roof top ac on a inverter would be very hard on a alternator.
    Cetane+ Thanks this.
  7. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Thats a good point. It works out as 1600 watts at 13.5 volts equals 118 amps plus whatever the invertor sucks up. Thats a lot of loading. Maybe we can design and market a system!
  8. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    You're a little late. Red Dot has been building aftermarket a/c systems for years.
    http://reddotcorp.com/
  9. Ridgeline
    22,098
    113,137
    Why complicate the simple.
    Don't bother with electric A/C kits or piece meal stuff, you want something that will be dependable.
    Just go here and talk to these guys --> Retroair, tell them what you want to do The kit should be less than $600) then go talk to an A/C shop that can do the work and have it installed.
    Cetane+ and damutt Thank this.
  10. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    ridgline thanks for the link :) i cna use that on my old IH truck, you just saved me at ton of cash and reserch, OP sorry for the hijack
  11. preppypyro
    36
    7
    Sep 10, 2013
    No worries about any hijacks, I appreciate all the replys and will look into each option! I will admit, I LOVE the retroair idea, thats sort of what i was hoping to run across, something like that!
    My father in law used to do some air conditioning repair and work, so I can get him to help me with the install and whatnot.
    Thanks a ton guys! Hopefully this helps someone out in the future as well. There is a lot of old iron on the roads and fields up here, and im sure im not the only one that has wanted ac in a non ac truck.
