AC evaporator keeps freezing up.
Discussion in 'Volvo Forum' started by RogueX, Aug 10, 2012.
  1. RogueX
    RogueX Light Load Member
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    Can anyone tell me how to get to the AC evaporator and blower motor area on an 07 Volvo 780? Is it through the dash on the passenger side or will I have to get behind the engine air filter? My evap keeps freezing up and I am told there is a freeze switch or thermostat switch that is basically a probe into the blower past the evaporator that tells the compressor when to ease up, if the air temp gets to 40°. The last tech I spoke to said this is the most likely problem given the other symptoms.Any help would be much appreciated...
  3. Ops85
    Ops85 Light Load Member
    97
    25
    Sep 10, 2011
    Madrid,IA
    turn to fresh air, no a/c to let defrost
  4. habfleet
    habfleet Light Load Member
    163
    23
    Feb 5, 2012
    elwood nj
    access is from the passenger compartment. you have to remove the bottem panel that wrappes around under the dash and then you can remove the upper part of the dash in front of the paasenger seat. pull out the blower motor assembly you should be able to see the probe.
    RogueX Thanks this.
  5. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    i need to get to the pass sideac evaporator housing on my truck its dripping inside the cab on to the toes of whomever sits pass side. i have to find a way to seal it completly and wonder why its dripping so much i think the box has a crack or drip hose is clogged but she drips alot.
  6. RogueX
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    Excellent, precise response. Just what I needed to know. Thank you very much! :biggrin_25519:
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yep, I wanna add, that evaporator temp senor is one of typical fails of Behr. If you work on Volvo, to remove upper dash cover of pass area you have to unscrew one bolt handle is held with (M8 with 1/2" socket), but my advice - remove handle fully becouse you can forget it is not secured and use it climbing in cab (especially dangerouse on cabovers). This handle hits your head and you fall out a cabin.... ( it looks funny, till other can see blood on pavement.
    I work for Volvo dealer for more five years and I saw so many not so funny accidents..... especially with cabovers
    RoadRanger^^, Mlaz Bogdanci and RogueX Thank this.
  8. rogueunh
    rogueunh Road Train Member
    1,082
    22,200
    Jan 4, 2011
    Curious if you found problem. My ac will run great for about 10-15 minutes, then slowly die with next to nothing coming out of vents. I turn off the ac with the fan running for a couple minutes, turn back on and it's nice and cold full blast for about another 10-15 minutes.
  9. RogueX
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    Yes! The thermostat switch was the problem, and your problem sounds identical to mine. The AC evaporator is freezing up. The part cost me just $47 and I was able to install it myself. Took about 2 hours. The advice from the others above about the install was exactly right. My AC works flawlessly now.
    rogueunh Thanks this.
  10. rogueunh
    1,082
    22,200
    Jan 4, 2011
    Ok thanks. Think I'll give it a try.
  11. Meagan
    Meagan Bobtail Member
    8
    Would this be the same on a 2006 vn610 with d12. I have mine apart but dont seem to be seeing this temp probe. Is it between the evaporator and the blower somewhere??
