Abs/ speed sensor removal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by djbattle, Aug 31, 2019.
  1. Truckers Report Jobs
  2. djbattle
    djbattle Light Load Member
    254
    142
    Jun 27, 2014
    I I mean to remove,I test them got 1.9 ohms need help asap
  3. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    The ABS sensor should just pull out. You have a picture of the back side. So if you can get ahold of it just pull it straight out. There is alittle tension clip on that sensor bore that can lap be removed. The new sensor usually comes with the clip and grease for it.
    On drive axles you usually have to pull the tires and drums off to get to where you can get ahold of the sensor. Trailers and steer axles you can usually get them fished out and back in.
    djbattle Thanks this.
  4. djbattle
    254
    142
    Jun 27, 2014
  5. djbattle
    254
    142
    Jun 27, 2014
    Thanks ,what is a good cheap abs scanner for 2014 prostar
  6. Working2party
    608
    729
    Feb 10, 2018
    Kansas
    Wabco will basicly give you the software. You just have to find a computer and data link.
    I can’t help you on a good and cheap. The company buys the best, and I borrow it as allowed when needed, but I’ve seen little DTC readers on the tool truck, I just ever can remember the price they say.... (after I quit sobbing about the amount I already owe)!!!
  7. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    You 100% sure not 1.9 K ohms ? 1.9 is the right number just time by thousand.
  8. djbattle
    254
    142
    Jun 27, 2014
    Not a pro at meter but I have 1.9 at all 4 wheels
  9. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Sounds all 4 sensor are good. Can you pay more attention to range switch what is the number it was set. If you set 200 1.9 is ohms. If you set meter to 2000 1.9 is 1900.
  10. Rideandrepair
    17,202
    55,791
    Aug 8, 2015
    Try pushing them in, too large of a gap will throw a code, it can be caused by too much wheel end play, also. I just did one on my trailer, using a screwdriver and hammer ( lightly) A wooden dowel or flat head punch works better, so as not to damage sensor wiring.Usually just slipped out a bit. Or the wire attached to the sensor is broken.
