Abs light
Discussion in 'Freightliner Forum' started by Rabjr98, Aug 9, 2014.
  1. Rabjr98
    Rabjr98 Bobtail Member
    Hello. On my 2013 cascadia my abs light comes on when I have my cruise control set. My truck is governed at 71 mph. If I catch a down hill run my truck gets up to 75mph and when the speeds drops back down below 71 and accelerates again the abs light comes on. It will stay on until I shut the truck off and restart it again. Then when I get past 10mph it goes out. Any ideas with this issue?
    Ray
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    It's most likely a defective ABS Wheel Sensor, or the ABS Wiring Harness could be ground out or shorting out on something or dirt or foreign debris could have gotten on the Sensor. If you had the Brakes or Wheel Seal changed recently, the Sensor could have been damaged upon reassembly.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    any MID 136 fault code at dashboard dispay?
    75 MPH.... I usually drive not faster 70
  5. rinkusaini
    rinkusaini Bobtail Member
    8
    Oct 20, 2017
    Can you help me sir ,
    Actually I have buy Freightliner Cascadia 2014 model 4 month ago . My concern with that my truck ABS light not working . When I switch the key and check ALL lights working fine but ABS tractor light not flashing or working and no fault code ondashboard . I also changed new ABS module . You have any idea that what a exact problem?
  6. Mateocargo
    Mateocargo Bobtail Member
    Did you fix the problem? I have same problem om my 2013 Cascadia
  7. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    The truck must be 'configured' for trailer ABS fault reporting in order for the tractor's instrument trailer-ABS warning light to work property. This involves programming the SAM-Chasiss module with the proper parameters and wiring the trailer receptacle center pin appropriately.
