We have had some bad luck or is it just poor design with our 2014 HINO 338.
2 years ago we drove with the ABS light on , not to long or far , but it was on. Not knowing that when ABS light is on it puts the transmission ( Allison ) into safe mode by locking torque converter, which in turn reduces the flow of oil. So by driving with ABS light on you in turn cook your transmission so I am told. Shame on us. We paid the price and put in a new Allison transmission 2000rm in.
But now 2 years later and 70,000klm on the transmission it fries up again with no warning ( and just 2 months ago we had the transmission fully serviced oil and filters). Abs light did come on a few months back as well, but same day we took it to dealer and they did a $300 brake job to solve that issue. So now we have to replace the transmission again , with the transmission shop saying it is due to ABS ( even though no ABS light on) and dealer shop saying not much for details/vague.
Any mechanics out their got insight into this?
Does this happen with other makes? ie the cummins motors?
thanks
ABS light sensor leading to Transmission Failure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Boxvan, Sep 25, 2019.
I would say there was dirty oil in the system, likely the cooler and/or cooler lines that had metal and other debris in it from the original failure that never got fully flushed and finally took its toll. Could have been a bad rebuild/reman. Oil filter change could have been done wrong, wrong fluid or not enough. I don't know enough about Hino to say further.
Working2party Thanks this. -
I'm honestly not seeing the correlation between an ABS fault and this transmission safe mode thing. Two unrelated systems. As far as I know, true automatics like Alisons are supposed to lock the torque converter for better efficiency (unlocked torque converters will always slip and cause inefficiency). Personally I think someone is feeding you a bunch of bull #### with that line about an ABS fault causing transmission failure.
pushbroom, Heavyd and Working2party Thank this. -
I gotta agree with both, somebody is feeding you a line so they don’t have to stand behind it. Could have been anything in Heavyd’s post and AModelCat is also right. Two different systems and even with the computer controls working together, I can see the reason ABS would change the operation of a transmission.
I would go back to these shops and ask them for a glass of water and a bigger spoon......
I’d have a hard time eating their BS!!Tug Toy Thanks this. -
I'm a mechanic also and call bs. The trans doesn't shift or do anything off abs
Big John Classic HQ Thanks this. -
Coming to this late, but the original poster is not wrong. The ABS light DOES cause the torque converter to NOT lock up which will overheat the transmission. Hino even came out with a TSB, SB-14-016 and a bypass device (wiring harness and 2 relays) to prevent an ABS malfunction from doing this. The problem is that the tone rings on the disc brakes rust badly and when the teeth start to flake off they push the ABS sensor out and trip the light. If you have a Hino and see the ABS light stop driving IMMEDIATELY and get it fixed.
Heavyd Thanks this. -
Interesting. Why'd they design something like that?
