Called a few TA's about pricing and a Loves. Looks like it's around 300. Anybody use Speedco? How much is yours and your experience?
About how much is it for your oil change?
Discussion in 'Ask An Owner Operator' started by Shotgun94, Aug 26, 2018.
Our local Volvo dealership was running a special a few weeks ago for a $199 oil change.
I use speedco only and with the upgrade to fleetguard filters it's right around $300. My favorite Speedcos are Lodi, Ohio and Joplin, Missouri.
I am about $5-600. Good oil, good filters, good service. Not a guy making minimal wage doing the service. If you can try tit have a good small town shop do everything.
Truck stops are ok but just be carful as they don’t care about you as the chance they see you again is slim. If this is a cheapo truck then sure run her to the ground. If not oil is like $100-180. Filter can be $50-175. Greasing takes time and if they don’t check or don’t care to check for anything else then what’s the point. To each there own.
Remember protect the money maker.Rickp, driverdriver, TripleSix and 1 other person Thank this. -
10 gal oil $100 (bought in 300 gal bulk)
First oil filter $26
Second oil filter $34
Fuel filter $31
1 tube of grease $3
Done by me and only me.
Doesn’t take 2 hours start to finish but I know it’s done right and completely. Also gives me a chance to put my hands on stuff under the truck I can’t see every day.
I do it between 15k and 20k miles.
I try and do a grease job every other weekend if I can. Takes less than 1/2 hour usually.Bean Jr., 20 Mule Team, wore out and 5 others Thank this. -
Let's go apples to apples.
Qualify what you're getting.
1) Mobile 15-40 Mineral.
2) Oil Filter.
3) Fuel Filter.
4) Fuel Water Separator Filter.
All filters Fleetgaurd.
5) Chassis Lube.
6) Check and adjust brakes.
7) Check and air tires.
8) Rotate Drives.
9) Check Gear Boxes.
$350.00 -
$240 do it myself. $38 for oil filter, $200 for Rotella T5 synthetic blend.
Plus grease -
Depends on what engine.
Sapp Bros gives you a free meal.
And old S60 oil change is only about $220. Tell what oil you want. Delo is number one right now with all trucks I've saw lately filled from factory with Delo. -
300 roughly at local ta. They know us so were not some guys they'll never see again. Includes 2 oil filters and the spinner cartridge (mack E-7) 9 gal of oil (t4) and gallon of Lucas
