?? about cleaning hot oil tankers.........
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jakescia, Feb 7, 2009.
  1. jakescia
    jakescia Bobtail Member
    32
    Aug 4, 2008
    Oskaloosa, Iowa
    We are looking at buying a tanker which has been used to haul hot oil/tar, or whatever the proper terminology is.
    What kind of pain in the tail is there to cleaning out the inside of the tanker sufficient so that it would not dump chunks into the water that we will be hauling for our sprayer, so that the valves would not get plugged?
    Or is the stuff stuck on the side tightly enough that it likely would not come loose even after thousands of gallons of water??
    We have no experience with this kind of tanker, and therefore would appreciate your comments.
    Thanks.
  3. Flyer
    Flyer Light Load Member
    183
    88
    Jan 20, 2008
    If your water temp is 350* you might have a problem. No it won't come off.
  4. dicky
    dicky Bobtail Member
    31
    8
    Aug 16, 2008
    st.paul , mn.
    best thing would be to get a load of # 6 fuel oil hauled in it then you could get it steamed out, it would be #### n span after that
  5. Bigstretch
    Bigstretch Light Load Member
    161
    30
    Jun 14, 2008
    NW IL
    You'll want to clean it, to use it for sprayer water (assuming it will be used with herbicides).
    Don't know if a hot water pressure washer with a rotary nozzle will be enough or not. You WILL need a rotary nozzle. Our washer puts out ~3000psi and can heat up to ~250*. Use "Oil Eater" cleaner (will have to google it since somebody keep removing my d*** links.). It is non-toxic and bio-degradable. Run it through the inductor line on the washer, or check out Tetra-Chem Industries Ltd. for commercial cleaners.
  6. dicky
    31
    8
    Aug 16, 2008
    st.paul , mn.
    If it had asphalt AC or PG grade in it last you wont be cutting it with the pressure washer. If it had a cutback asphalt or a fuel oil #5 or #6 in it you could cut it with the pressure washer and some good soap as suggested above . Then a simple acid wash would clean it right up.
  7. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I would pass on the trailer unless it's really cheap (like free) If it was hauling asphalt IF you can get it out the left over residue will cost you a fortune to dispose of (hazardous waste) plus those hot product tanks go through so many heat cycles through their lives they inevitably start cracking and leaking. And since they are so hard to clean the repair is half assed most times. I hauled AC asphalt two summers ago and those trailers were never cleaned and some were 20 years old. I was told it would be around 5 grand to actually get a tank wash to do it but I wouldn't swear on that (trucker story)
