A weird new one: SPN 1231 FMI 9
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PermanentTourist, Apr 4, 2023.
  1. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    881
    Nov 9, 2016
    48 states + Canada
    It says "Emission System No Comms Detected. 25% derate"
    And the truck goes into auto shutdown.
    It's been sitting for a couple of days and got jumpstarted and then this began.
    Is it a loose wire or perhaps a blown fuse somewhere or something?
  3. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    I checked the fuse in the power distribution box, I unplugged and replugged the ACM... now on my way to Walmart in an Uber so I can buy a proper voltage tester (it's 10pm here and it's the only thing that's open)
  4. JB7
    JB7 Heavy Load Member
    779
    1,194
    Dec 13, 2022
    Laurel, MD
    Possible causes: • Over/under voltage supply to the ACM module • Fault set during a reprogram event • Loss of power to the ACM • Loss of ground to the ACM • Loss of ignition switch power to the ACM • Open in the CAN-H/Can-L communication circuit to the ACM
    PermanentTourist Thanks this.
  5. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    Yes, I have that PDF too lol
  6. Hammer166
    7,458
    27,028
    Aug 18, 2007
    ~8600+' and loving it!
    Had something very similar in a DD13. Shortly after delivery this truck dropped the driveline because the front u-joint wasn't tightened up. It did a good job of wrapping and pulling some of the wire harness. 2 years later the communication line to the ACM finally grounded out where it had been pulled tight against the OneBox. IIRC, he was in the shop for a week before they finally found it after running out of parts to throw at it.
    Oxbow and PermanentTourist Thank this.
  7. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    That's exactly why i'm going under there with the multimeter. It is ~probably~ the harness and a grounded wire, but I want to be sure. Even if I don't end up changing the harness myself, I don't want them throwing a new ACM at me for no reason.
    JoeyJunk and Hammer166 Thank this.
  8. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    Update: I found the bad wire!
    Spliced it with some random wire i scavenged from a 12v charger, and i'm good to go. Saved myself at least a couple grand and a two day delay...
    Oxbow, Magoo1968, IH9300SBA and 2 others Thank this.
