A lot of oil coming out of air tanks and purge valve need help .
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, Mar 1, 2018.
  1. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    hey guys wondering if ya can help me with a problem I’m having . My Bendix purge valve seems like it purges oil. Checked my air tanks and it shoots out oil. Is it time for a new compressor ?? I noticed I burn about a gallon a week of oil. Truck has noticible blow by also . But don’t think that has to do with it . It got it from one week to another . I’ll post some pic of my compressor . It’s on. Peterbilt 379 1997 . 3406 e model thanks guys
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Remove the intake or charge air from the air compressor to isolate the engine from the compressor. Inspect the intake for wetness or oil coming from the engine. Run the engine with the discharge line off and the compressor building...hold a piece of cardboard or sheet of paper to the discarge port at the compressor. If it spatters the paper with the intake off the compressor is passing oil, no question. If the intake is wet suspect engine issues.
    Air systems can be a bugger to clean of oil. Flush the line from compessor to the dryer really good and replace the dryer complete with a reman or new.
  4. Nestor
    160
    23
    Oct 21, 2015
    Thanks for the reply man. So can u shoot me in the right direction on how to do that . I’ll upload some pics
  5. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Sure, intake is on the side. Discharge is the stainless braid on the top of the compressor.
    Rideandrepair and baha Thank this.
  6. Nestor
    160
    23
    Oct 21, 2015
    Is this the intake ? In goes into block (first pic) second pic what is that line ? It goes over to the other side of engine?maybe coolant ? And third pic this was leaking
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    The third pic is intake,facing away from motor.
  8. Nestor
    160
    23
    Oct 21, 2015
    So I took off intake the one u said and there’s suction on the intake. Nothing coming out of the line
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    First 2 pics are coolant in and out. The last pic on the bottom with the aluminum 2 bolt flange is the intake.
  10. Nestor
    160
    23
    Oct 21, 2015
    Thanks buddy . So I took off discharge line and no oil . I disconnected intake . Still no oil out the discharge.the intake on the compressor does accumulate oil on that Elbow fitting . It seems kinda wet instide there
  11. Nestor
    160
    23
    Oct 21, 2015
    Also the small top line coming out of the air governer is all wet in oil
