A few questions about shifting 8 Speed.
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Feb 11, 2018.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    842
    1,616
    May 15, 2017
    Hello, I am a new truck driver. I have about 2 months of experience driving an 8 speed transmission. I worked with an owner operator who didn’t really teach me how to shift, and more times than I can count he shifted the gears for me (I don’t understand why he did this). I have no problem shifting up, my main problem is shifting down. I recently got an offer for a $21 an hour job with my close friends company, it’s a small company and not a major one. My friend said the boss is willing to give me one week training before sending me out on my own. I haven’t been in a truck since last year June, so it’s been a while since I’ve driven. I’ve always had these questions about gear shifting:
    1. What happens if let’s say I’m in gear 4 shifting to 5 with the splitter and I accidentally put it into reverse? Will the truck actually go into reverse?
    2. I have always driven on long straight stretches of road on the trans Canada highway, I didn’t really ever have to shift gears often. With 10 speed the 25 mph 2+5 would be gear 7, but with a 8 speed what are the speed ranges? (The entire fleet is freight liner)
    3. Is one week even enough time to learn how to downshift? I’ll be with the company trainer for about 10 hours per day for about 5 days.
    My dad is also a truck driver, he told me once I figure out the speed ranges for each gear, it will become a walk in the park. Is this true?
    If anyone is trying to bash me for not knowing how to drive manual and I already have my class A license, I got my license in Ontario, passed in an automatic truck, but I’m not restricted to driving only autos. I didn’t have enough money for a proper school (costs 5k for a reputable school). I had no choice but to get my license at a mill, which only really taught me how to pass the road test. I wasn’t really taught how to drive manual, except for what my idiot owner operator taught me which was only up shifting. On my final trip that I worked I was getting the hang of downshifting and was doing it without any assistance. But after that I became unemployed for 8 months trying to find a job.
    I’m hoping there are some pros out here that can give me pointers on down shifting an 8 speed.
  3. LWT104
    LWT104 Light Load Member
    172
    353
    Jan 12, 2017
    Around the corner
    You worry too much. Just drive it.
  4. RedRover
    RedRover Road Train Member
    1,791
    2,612
    Sep 10, 2016
    Corsicana, TX
    Upshift at 1500-1600
    Downshift at 1100-1200 (bump your rpm's to 1500-1600)
    When I am downshifting, what I will do is apply brake down to say 1000 rpm and shift to neutral. As I am shifting into the lower gear, in one fluid motion I will rev the engine and shift... if you can time it correctly, the #### thing just falls into gear.
    brake to 1000... 1 move: clutch shift to neutral... 1 move: rev to 1500 shift. The recovery speeds aren't actually terribly different for a 10 speed and an 8 speed. If all else fails, like 95% of the time I just shift to neutral anyway and brake down to a stop at a red light. The only time that may give you problems is if you have a light that turns green on you and you're still rolling and still in neutral. Then what gear do you put it in?
    x1Heavy and Canadianhauler21 Thank this.
  5. Canadianhauler21
    842
    1,616
    May 15, 2017
    That’s my main freak out, when I’m pulling up to a red light and suddenly it changes to green and I’m rolling in neutral to the lights. None the less, I appreciate the tips!
    x1Heavy Thanks this.
  6. NuCar Carrier
    NuCar Carrier Light Load Member
    132
    314
    Jan 23, 2016
    I've been shifting gears a long time, 1970. It's hard to explain it when it's second nature.
    On a 10 speed trans, add your numerical speed, say 45mph 4 + 5 = 9, 9th gear, 35mph 8th gear, get it?
    No matter what you're going to have to 'rub' some gears, rev up the throttle and see what gear likes the revs. The H patterns on trucks are often so wide or narrow you're not sure which gear you're actually rubbing until you get used to the truck.
    Don't worry you'll make mistakes but as far as I know it's impossible to shift into reverse while you're moving forward at any speed but I never tried.
    If you're approaching a stop sign / red light and want to downshift and brake, you may not have enough feet to throttle up to shift down and brake at the same time, just pick one or the other and find a gear after.
    If you're pulling a hill and have to shift down fast leave the jake brake on a bit, (assuming you don't use the clutch) it will help. Beware if you shift to fast from hi range to low or you'll put the trans in a false neutral. You'll have to go back into neutral for a second to let the trans catch up. I never use the clutch except to start out, couldn't double clutch if I had to.
    Your original question was about 8 speeds and I don't think they have a high and low range.
    Don't sweat it, you asked the right questions, you'll have it down in a short time
    Canadianhauler21 Thanks this.
  7. TripleSix
    127,975
    If you're not fully stopped and the light turns green, if you're loaded light, shift to the lowest gear on the high side of the transmission. If you're loaded heavy, shift to the highest gear on the low side of t he transmission.
  8. Canadianhauler21
    842
    1,616
    May 15, 2017
    Thanks dude! I really appreciate your advice, I guess I’m getting anxiety over nothing.
  9. Canadianhauler21
    842
    1,616
    May 15, 2017
    Wow man, thanks! I think this is one of the main points I have been looking at for weeks on end. I’m glad I finally found the answer. Once again thanks!
  10. TripleSix
    127,975
    Btw, an 8 speed is actually a 9 speed...you just never use the granny gear.
    scottied67 and Canadianhauler21 Thank this.
  11. Canadianhauler21
    842
    1,616
    May 15, 2017
    Ah I see, thanks for clearing up this misunderstanding. I’m still a new driver and still learning the different kinds of transmissions. I always thought it was 8 because of 1-2-3-4 High 5-6-7-8. No wonder I had a hard time finding YouTube videos for 8 speed.
    TripleSix Thanks this.
