A/C working in bunk but not in cab.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TGUNKEL, Apr 12, 2014.
  1. TGUNKEL
    TGUNKEL Light Load Member
    229
    160
    Mar 16, 2013
    Spokane,Wa
    The A/C in my 94 W900L works freakin awesome in the sleeper but hardly at all in the cab. Expansion valve? Or something simple? I know, that was funny, I laughed as soon as I saw what I typed!! Simple, WTH was I thinking!! Any thoughts on the A/C??
    Gunk​
  3. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    Probably the expansion valve.
    TGUNKEL Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Cut off heater valves to cab, Possible low freon,if you have sight window on dryer look for bubbles passing thru glass.
  5. TGUNKEL
    229
    160
    Mar 16, 2013
    Spokane,Wa
    All water valves are closed. As stated, cools awesomely in the bunk(down to 40 degrees) but hardly cooling in the cab.
    Gunk
  6. BeenJammin
    BeenJammin Light Load Member
    256
    118
    Dec 17, 2013
    If you got good air flow out of the dash, I'll second kwswann's motion, expansion block.
  7. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Nope the issue is you have too much money just find a good mechanic and i,m sure he will lighten the load in your wallet my trucks allways know when i am afflicted with this problem
  8. TGUNKEL
    229
    160
    Mar 16, 2013
    Spokane,Wa
    Haha!! No joke there! The mechanic part not the excessive cash in wallet part.
    Gunk
  9. baha
    4,137
    2,835
    Jul 25, 2013
    ga
    Pull cover off box under dash with motor hot ck. heater core to be sure, gages on comp. will help to see freon low if you dont have sight glass to look for bubbles on dryer, The exp. valve on 90s is not easy to get off without twisting off lines.
  10. BeenJammin
    256
    118
    Dec 17, 2013
    Aww now, we ain't all greedy. My retirement plan in a few years will be how to figure out a way to pay off all the debt I've accumulated by going into business for myself a couple of decades ago. Looks like the plan is to just keep piling on the debt. I hope debt is like what they say about money, you can't take it with you when you go. Bet my wife hopes I do take it with me.
  11. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Does yours have the electronic heater control valve? If it's working sufficiently in the bunk, I doubt refrigerant is your issue, as you'd be experiencing insufficient cooling in the cab and bunk alike. I saw you said the coolant was cut off.. how well does the bunk cool when you have it on? Cutting off the coolant should make the AC blow cooler, but it shouldn't be the difference between cold and warm air blowing out.
