A/C Lines Freezing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 38short, Jun 24, 2013.
  1. 38short
    38short Light Load Member
    63
    12
    Sep 10, 2007
    Katy Tx
    I have a 2007 Freightliner Century. The A/C lines are freezing , and when it does it it blows but not real cold air. The problem is it can run the whole day and not freeze and then out of the blue it freezes. I can shut it off and defrost it and it will run and blow cold and then out of the blue freeze up again. Any help appreciated.
  3. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    I think you'll find it isn't your lines freezing... it's probably your evap icing up. Make sure your dash housing drains aren't clogged.
  4. 38short
    63
    12
    Sep 10, 2007
    Katy Tx
    What gets me is that I can shut it off and defrost it and it will run the whole day and even longer and not freeze up and then boom the lines under the cab are frozen .
  5. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    I'm not certified in A/C but believe the problem likely low freon... I know it sounds backwards but that was what fixed mine.
  6. 38short
    63
    12
    Sep 10, 2007
    Katy Tx
    That was the first thing we checked , the freon level.System has the right amount of freon.
  7. Homemade1959
    Homemade1959 Light Load Member
    130
    47
    Jan 21, 2012
    any of the 48 states
    We have a 2005 Columbia ours was doing that, we also check system for freon and leaks but it's the thermostats probably need to be replaced on its there is two of them it's about a $400 job, the thermostats are only $40 a piece from freightliner it's all in the labor.
  8. 38short
    63
    12
    Sep 10, 2007
    Katy Tx
    I have changed the thermostat the one at the blower motor inside the cab, where is the other one located at? You say there are two thermostats is the one at the blower motor a thermostat? Where is the other?
  9. Chuckie86
    Chuckie86 Light Load Member
    70
    30
    Jun 19, 2013
    Lake Butler, Florida
    Check the in-cab air filter and coil make sure they are clean if either or both if them are dirty it will cause a freeze up and poor cooling due to lack of air flow also check the consider big radiator looking thing infront of the actual radiator if it gets plugged up with bugs and dirt that will cause freeze up and poor cooling aswell ac is all about air flow if the system is working properly
  10. Ridgeline
    22,112
    113,286
    What thermostats?
    There are expansion valves or orifice tubes that are used.
    I am thinking that if your evaporator is freezing up, as mentioned it has a lot of water or moister in the unit and the drains are plugged.
  11. 38short
    63
    12
    Sep 10, 2007
    Katy Tx
    I keep saying the system can run for a whole day and not freeze up. I'll shut her downand the next morning it will run for maybe three hrs. and then freeze up(lines under the bunk)
