A/C Fill Freon Fill Amount
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sailboatjim, Apr 9, 2015.
  1. sailboatjim
    sailboatjim Light Load Member
    292
    173
    Aug 27, 2014
    Boston, Mass
    I've got one of these Bergstrom under seat A/C units I'm working on and it is in an International with sleeper.
    I'm guessing it's going to be 3 to 3 1/2 pounds or 36 and 44 oz but I don't know for sure. The only thing I could find on it said 134a.
    Sticker is gone completely.
    Got it vac down and ready to fill.
    Anyone?
  3. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    If you can't find the spec just fill it until pressures are correct
  4. sailboatjim
    292
    173
    Aug 27, 2014
    Boston, Mass
    I put 36 oz. in it waiting for a reply and the low side pressure was 30 and the high side never gets above 250 and then the fan kicks on and it heads down to the 150 range or so. The fan kicks off when the low side pressure reaches 20 or so. It takes quite a while for it to reach 250 on the high side too. I'll bet I'm still just shy of the correct fill but the sight glass on the new dryer shows no signs of bubbles at all. I got in it and drove around and it's cool but not cold. I can see the expansion valve opening and closing on the pressure gauges. I evacuated it for about 45 minutes with a vac pump. I had to replace all the freon check taps and o rings. They were all leaking. Like I said the Bergstrom under seat a/c has no freon fill info on it at all and I have search the web high and low and haven't found it.
  5. asavage1576
    62
    36
    Mar 18, 2013
    Dallas,Tx
    Ya. I would add a little more. Our day cab Pete 365's take 44oz
    sailboatjim Thanks this.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    3lbs if you have a Sanden, 4lbs if you have a CCI compressor.
  7. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    that sounds pretty close to correct pressure wise if charging on a relatively cool day. keep in mind that pressures will be higher on a hotter day than on a cool day.
    if it happened to be fairly hot out when you charged it i might add a touch more Freon. charging by pressure is not perfect but you can get the charge pretty close. i don't have a way to weight my Freon so i normally just charge by pressure so you should be fine just charging by pressure in absence of knowing the Freon amount the system holds. i really should get some kind of scale to put under my refrigerant bottle.
    overcharge can effect system performance as much as undercharge so sometimes you have to resist the urge to "add a little more"
  8. sailboatjim
    292
    173
    Aug 27, 2014
    Boston, Mass
    It's a CCI Piston type compressor.
    I've got 3lbs in it now.
    48 oz
  9. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    check your pressure after the system has sat for 8 or so hours, the pressure should be very close to the ambient temp, 70 psi at 70 degrees F . if it will cycle the compressor and kick the fan in you are really close, overcharge creates extra load and lots of extra heat
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    When dealing with the unknown or the just does not do right units I charge by thermometer with in allowable pressure levels. Open all the doors and set unit to fresh air if applicable. Put therm. in outlet vent with a known low charge and add freon about 4 oz.at a time. Allow time for system to stabilize after each addition and check temp.( takes a few minutes 3-5 ?). Keep adding intell the temp. increases and back up.
