a/c expansion valve
Discussion in 'Peterbilt Forum' started by needtoknownow, Jun 22, 2014.
  1. needtoknownow
    needtoknownow Bobtail Member
    12
    Sep 14, 2013
    would someone kindly tell me where the a/c expansion valve is located on a 2004 pete 379. I dont have a manual
  3. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    Expansion valves are normally located at the evap. inlet.
    needtoknownow Thanks this.
  4. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    You should have one on firewall and one in sleeper
    needtoknownow and Davidlee Thank this.
  5. wore out
    wore out Numbered Classic
    15,319
    184,959
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    04 will not have an expansion valve. They use an oraface tube in the high side line either where the line goes into the evap core at the firewall or the inlet side of the condensor. Most of the time its in the evap core side, they sell a tool to get them out but a small pair of needle nose usually works. Different colors are different screen sizes so use the same color. They are directional as well.
    needtoknownow and Klleetrucking Thank this.
  6. Ridgeline
    22,103
    113,210
    AND if you need to replace it, chances are you need to flush the entire system to get rid of the junk that plugged it up because they do not wear out.
  7. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    I recall back in the 70's I was driving about a 74 or 75 conventional KW. The sleeper AC was not blowing cold air but the truck AC was working just fine. The shop at Quartzsite, AZ said the expansion valve was stopped up, & he did not have one for it. He took a small drill bit & drilled in out by hand, after that it blew very cold air & I never had no more problems with it.
  8. EverLuc
    EverLuc Light Load Member
    295
    101
    Feb 18, 2013
    My 05 379 has the orange orifice tube on the firewall and an expansion valve on the bunk evap. You will have to take up the panel under the matress (passenger side).
