A/C blows cold but it doesn't blow hard enough
Discussion in 'Freightliner Forum' started by FLDJR, Sep 26, 2017.
  1. FLDJR
    FLDJR Bobtail Member
    Hey guys! I have a 97 Freightliner FLD120, and I'm having issues with the a/c.. it blows cold but it's not blowing hard enough. The fan is on high but it's blowing like it's on low.. I'm melting out here! Please help
  3. Blackshack46
    Blackshack46 Road Train Member
    Imma follow this. I have the same problem with an 03 mack ch. Blower is running, and its on high..... but barely feel it. The mechanical linkage on mine is an issue as well, because not all vents get closed when you only want say the face vents. You still get defroster vent a little and the feet get some.
    Do you have that problem? Do you have mechanical linkage? For a 97' I would assume so.
  4. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    If I had to guess I would say the evaporator is probably blocked with crud and your not getting good air flow thru it.
    Remove the blower fan and see if you can shine a light in there and see if it's blocked.
    wore out Thanks this.
  5. bzinger
    bzinger Road Train Member
    16,593
    65,735
    Dec 10, 2014
    omaha , ne
    Sounds like one of my exes lol
  6. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Check the filter, if someone hasn't thrown it out, then the coil is plugged
    misterG and bzinger Thank this.
  7. Brandt
    Brandt Road Train Member
    4,403
    5,936
    Sep 17, 2012
    Could be coil freezing up or clogged or air filter is clogged for front blower or the blower motor is worn-out. If you turn a/c off and more air blowes afer 5 minutes or something then you know the coil is freezing. If not it could be blower motor in an older truck or if lucky the air filter for front blower is clogged.
    truckthatpassesyouby Thanks this.
  8. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    Don't forget to clean your vents too.
    Had a pair of gloves, and a burger wrapper, and loose paper come out of the vents on an old L9000 we have in the yard.
    After that the air could blow you about out of the truck.
  9. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    evaporator plugged need to remove to wash it and install back and should be all good.
  10. Old Man
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    You don't need to remove it to clean it.
  11. Blackshack46
    How do you clean it then?
