99 international 4700
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sjr307, May 1, 2018.
  1. sjr307
    sjr307 Bobtail Member
    8
    Mar 4, 2018
    Dt466e with Allison trans. This is the first automatic I've worked on. I can not for the life of me get power to the starter solenoid. It will start with it jumped out and key on, what is between the key and the starter on these automatics that I should look for? Thank you
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Fuse in the box under the hood? Drivers side fire wall.
    Some had another relay near the starter or on the fire wall. Neutral safety switch?
    sjr307 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Crank inhibit relay. Should be behind the blower box panel in front of the passenger seat.
    BoxCarKidd and sjr307 Thank this.
  5. sjr307
    8
    Mar 4, 2018
    Changed it , breaker 4 now opens if I try to start it. There is a draw when you turn the key now and try to start it. It looks like I'll be looking for bad wires
  6. RTR tech
    RTR tech Bobtail Member
    8
    Mar 18, 2018
    Couple of thoughts. Those trucks had issues with leaking windshield/cowl, causing corrosion on back side of fuse box. I dont remember which fuse, but I had a no start problem on a truck once which was shorted wire for neutral safety/ clutch switch circuit.(the same circuit was in there for either transmission, they just plugged it in at different place.) Good Luck.
