I have a T600 with no high idle. I've checked pressure switches, brake , and clutch switches. Looked for mercury switch but looks like it was deleted. Anybody have any tips where else to look. Also anybody know where to find wiring diagrams for this truck. Thanks
'98 KW T600 no high idle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ashleyschaffer, Jan 9, 2018.
Usually park/brake/ clutch switches fix it up. S/n?
SAR, spsauerland and Ashleyschaffer Thank this. -
Actually the s/n is 1XKADR9X4VR745175, I read wrong notes earlier, my apologies.
Are you sure ECM is programmed to allow high idle?
Here is the DDEC 3 diagram for serial number posted.
Ashleyschaffer and SAR Thank this. -
Also swapped ECM from identical twin truck and high idle worked when ECM was put on other truck so that tells me it’s on.
Does cruise control and engine brakes work?
SAR Thanks this. -
Also have you tried hi idle with vehicle speed sensors at transmission disconnected?
SAR Thanks this.
